Technical Wishbone bracket
Discussion in 'Traditional Hot Rods' started by Omarsvette, Apr 13, 2021.
  1. Omarsvette
    Omarsvette
    from Arizona
    The bracket I have is to tall. About half of the bracket will need to be cut off. But the frame will drop more when I put the hemi in. So I’m thinking of cutting the bracket and tacking it in place then put the motor in and see how things line up and adjust the bracket. Does that sound right?
    Is there more distance created in between the bracket and batwing when the frame lowers and levels the spring?
  2. Omarsvette
    Omarsvette
    from Arizona
  3. alchemy
    alchemy
    The hairpins are used to adjust the proper caster into your axle after the car is done. Maybe you can adjust the front clevises enough to get your caster, or maybe you need to pay more attention to where the back end of the hairpin sits, up-and-down. You will need to mock the car up at final ride height and rough in the adjustments, before you weld anything.
    If your hairpin pivot point is exactly center of the arc compared to the spring's caster (the face of the spring), then you wouldn't have to worry about the length changing. If the clevises are adjusted to make the hairpin end upward or downward from exact center, then the length will change slightly as the car "bounces".
  4. bantam
    bantam
    I bought that same bracket and cut off at least 1-1/2" after initially tacking it to the bottom of the 1934 frame rail and then putting the motor and ****** in but no body on it. It hangs too low if you don't modify it in my opinion.
    chryslerfan55 and Omarsvette like this.
  5. Koz
    Koz
    The concept is to have the spring/axle rotate through a constant arc with suspension travel. In other words there should be no bind or bend front or rear in the spring from fully open to fully compressed. I've found on a typical deuce ch***is, with a reversed eye spring the pivot point on 31" eye to eye hairpin is 2 1/4" to center, from the bottom of the frame. As a side note, The SoCal brackets are way nicer and more substantial, along with somewhat better looking than the Speedway version, (which I ***ume is the ones you have there). Nothing the matter with them, just a little ugly to my eye.
    If you are reasonably handy you can make your own brackets of 3/8" P&O and add a 5/8" long sleeve drilled to 5/8" for the crossbolts or reamed 1/12 taper for early Ford ends. The early Ford ends don't fit the 5/8" Speedway hairpins though so you're kind of stuck with the crossbolts.
    I really like the way you have the crossmember in there. Neat project!
  6. Omarsvette
    Omarsvette
    from Arizona
    Thank you so much fellas. You all answered my question with great info.
    Koz likes this.
  7. Omarsvette
    Omarsvette
    from Arizona
  8. Omarsvette
    Omarsvette
    from Arizona
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yes there is " some" caster adjustment , but not much without exposing too many threads or changing the wheelbase and the arc in the axle travel in relation to the spring
  10. cadillacoffin
    cadillacoffin
    Andy and chryslerfan55 like this.
  11. mtb1981
    mtb1981
    Omarsvette likes this.
  12. Koz
    Koz
    Sweet!
  13. Omarsvette
    Omarsvette
    from Arizona
    Got the hair pins in, next motor mounts 8B220EEB-0405-44BD-B114-7DFD06CA4763.jpeg D375D910-700A-4ABB-A160-4FD3BFFEC256.jpeg
    Just Gary likes this.
  14. Omarsvette
    Omarsvette
    from Arizona
    Some updated pics.. 54FD9025-289A-44BB-9D6A-B7B11F996DC2.jpeg 3CD9D0B1-9059-47B5-80E5-E0EE014F2C77.jpeg 699A93B7-4365-422D-94DF-676D740FAB27.jpeg
    RICH B, Just Gary, alanp561 and 3 others like this.
  15. dirt t
    dirt t
    GREAT HOT ROD !!!!
  16. 5w30
    5w30
    super nice rod wondering how wide are the rear rims??
  17. Omarsvette
    Omarsvette
    from Arizona
    Thank you, there 7s
  18. 41rodderz
    41rodderz
    from Oregon
