Wishbone question
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Apr 20, 2013.
  1. harleycontracter
    harleycontracter
    I have a set of what is suppose to be split bones from a 35-35 Ford. I originally installed them with the welded seam on the bottom as I thought it should be. By installing it that way it tilts the axle forward. I took them off and put the seamed side up and it's perfect. Is that right or did i do something wrong. I can post pics on Monday.
  2. seam should be up
  3. harleycontracter
    harleycontracter
    Should be?? Really if that's the case I'm good. Thank you It's been making me crazy thinking I had something wrong
  4. oj
    oj
    The welded seam is down. Typically you have to make a 'piecut' up where the forged yoke section is **** welded to the tubing. The forged section has a shoulder that goes up inside the tube about 3/8ths or so. I make my cut right at that edge. I made a simple fixture that bolts up inside the front crossmember (replacing the spring) and aligns the axle to the crossmember as the front crossmember has the 5-7deg castor angle built into it, i then attach the bones to the axle and attach the other end at the frame and do some tack welds. I do both sides and take them back apart, lay them on top of each other and they should match. If they do, weld'em up.
  5. i guess you can have it anyway that works for you.....but Ford had them with the welded seam up when 35/36 fords left the factory
  6. oj
    oj
    You're probably right, i have a bunch of 'A' bones and the seam is down.
  7. i just looked at my `36 and the seam is up , do A's and 32-34 have the seam down from the factory? i just never paid any attention
  8. HOTRODPRIMER
    HOTRODPRIMER
    Seams are up. HRP
  9. TagMan
    TagMan
    Seam is up on my '36
  10. i am curious.....do A's and `32-`34 have the seam down?
  11. krylon32
    krylon32
    from Nebraska
    Model A's thru 34's had the seam down. Seam went up in 35.
  12. sawbuck
    sawbuck
    from 06492 ct
    yes ...seam down
  13. HOTRODPRIMER
    HOTRODPRIMER
    DD,,,Deuce Down. :D HRP
  14. "Seams" to me we have a real difference of opinion on this one!
    I'm betting a lot of them have had the seam "reversed" at some point for looks.
  15. actually , we "seam" to all agree now......A , 32-34 is down, 35 and up is up
    learn something new every day , never paid attention
  16. harleycontracter
    harleycontracter
    Thanks for all the help. Problem solved. I was hoping 35-35 seams were up otherwise I screwed up somewhere
  17. 40FordGuy
    40FordGuy
    You didn't screw up.... And before making any pie cuts, check the caster angle. It may be ok as is.
    4TTRUK
  18. 296 V8
    296 V8
    from Nor~Cal
    Grind it smooth - grind a grove - tig grove - grind smooth - all cool
