Technical Wishbones Split or Not
Discussion in 'Traditional Hot Rods' started by dmdeaton, Apr 7, 2018.
  1. dmdeaton
    dmdeaton
    My banger build, just getting started and parts I have so far:
    30 Model A 4 door.
    No fenders, original axle dropped some, wishbones split and welded with a little camber. Still have original wishbone also. Banjo rear end with original bars bolting up to nice beefy brackets on the 5 speed ******. New spindles with juice brakes. F100 steering box. I am not going with cross steering.
    Local older hot rod guys telling me he wouldn't split the bones.
    Other options are whether or not to use the float a motor mounts. In my opinion this would make the whole setup a little springy if the bones were left attached to the ****** and flywheel housing with the rubber mounts.
    I understand some reasons for splitting the bones is for installing larger engines. I am trying to **** up as much info as I can before I make the decision.
    what do you guys think?
  2. dmdeaton
    dmdeaton
  3. Texas Webb
    Texas Webb
    Don't you mean caster?
  4. woodiewagon46
    woodiewagon46
    from New York
    I doubt by using the Float-A-Motor mounts that it will make your car a "little springy". I have been playing with Model A's since 1968 and have never heard that complaint. The only way to alter the Camber on a beam axle is to bend the axle. Wishbones wether split or stock will affect Caster.
  5. dmdeaton
    dmdeaton
    Caster
    Sorry
  6. dmdeaton
    dmdeaton
    Didn’t mean make the car springy
    If front and rear bones are pushing against a engine and trans that are held to the frame by rubber donuts it seems that would not be as good a setup as pushing against a more solid mount on the frame
  7. RICH B
    RICH B
    No sense splitting the wishbone if you are using the A motor.
    lurker mick and zzford like this.
  8. brokenspoke
    brokenspoke
    ^^^^^what he said ^^^^^
    zzford likes this.
  9. dmdeaton
    dmdeaton
    Ok already, I wont split my wishbones. :) Thanks for the replies. My local old timers tell me the same thing. And they used to race these things. I don't know why I am so hung up on this? Sounds like the problems outweigh the gains.
  10. wheeldog57
    wheeldog57
