Technical with all the 6v vs 8 v batterys....
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Jan 22, 2025.
  1. ALLDONE
    ALLDONE
    I load tested it yesterday... dropped to just under 6v... where the 6 v dropped to just under 5...my plan is to try to get it to charge to over 8... but my real plan is to do a 12v conversion...but a this point all the battery does is start the motor.. and run the 6v fuel pump..... so not a real concern... learning about 8v battery's is interesting... but most likely info I'll probley never use again...
  2. ALLDONE
    ALLDONE
    this nipped it at the bud quick....lol
  3. ALLDONE
    ALLDONE
    you forgot chewing gum wrapper/cigarette pack foil
    firstinsteele likes this.
  4. 1971BB427
    1971BB427
    from Oregon
    If your 8v. charger didn't bring it up over 8v. it might mean your battery has failed and maybe wont ever take a charge. If your battery warranty isn't good, it might be time to decide if you want to convert it to 12v. or buy another 8v. battery and go the route of making it charge? Or maybe just buy a 6v. battery and be done?
  5. ALLDONE
    ALLDONE
    WTF>>>>> guess I need new gl***es...when I looked, looked like it said 8 volt.... after 2 days... sum ting wong...thought, I should get a flash light and magnify gl***....... ahhh ****... it's a 6 volt battery..... oh well... it's fixed...on a 6v trickle charge it stays at 7.1 volts... interstate battery...
  6. twenty8
    twenty8
    Look at the bright side. You now know that you can charge a 6 volt battery with a 6 volt charger, a 12 volt charger, or with a brand new 8 volt charger......:rolleyes::D
  7. 1971BB427
    1971BB427
    from Oregon
    Surprised you didn't fry the battery with a higher voltage charger, or at least mess up the chargers.
    Truckdoctor Andy likes this.
  8. patsurf
    patsurf
    do you own a repair shop or just are a customer at the one(s)? you mentioned?
    2devilles and tubman like this.
  9. tubman
    tubman
    It's not that hard to see :
    3 caps = 6 Volt
    4 caps = 8 Volt
    ALLDONE and 2devilles like this.
  10. Ebbsspeed
    Ebbsspeed
    I use a 12 volt charger with a 6 volt (1154) lamp in series with the circuit. Wire the two filaments in parallel, and the lamp will p*** two or three amps of current, and eventually bring the battery up to it's rated voltage. Trickle only, since the 1154 light is a current limiter.
    ALLDONE likes this.
  11. chickenridgerods
    chickenridgerods
    from DSM, IA
    He gave you the answer on how to charge that 8V battery that's in your vehicle. You don't. You fix the issues that predicated the 8V band-aid. If you can't afford a battery, which is a maintenance item regardless of its voltage, you're probably in the wrong hobby. That $50 8V charger was 1/3 of the way to buying a new battery.
    As you've also found out, if your vehicle's charging system hasn't been changed to output >8V, all you're going to do is discharge that 8V battery back down to a 6V charge.
    Nobody here is driving their hot rod in a temperature as you describe. Especially the OP, who is in Las Vegas.
    An 8V battery on a 6V system is a band aid. Switching to 12V allowed the OEMs to run higher wattage loads with less current, which means lighter gauge wiring and switches.
    G-son and ALLDONE like this.
  12. F&J
    F&J
    Here we go, "oem switched to 12v to use lighter wire and switches". Yea right. Explain why economy car manufacturer Volkswagen waited until 1967 to so called "save money" and finally switched to 12v. Explain why Chevrolet waited till 1955 to switch to 12v when corporate sister Olds went 12v in 1953. Could it have anything to do with Chevy getting an overhead v8 in 1955? Nah, it's just coincidence. Geez, the internet, where self proclaimed geniuses are born every millisecond
    ALLDONE likes this.
  13. ALLDONE
    ALLDONE
  14. ALLDONE
    ALLDONE
    not true.... I was born 72 years ago...lol
  15. ALLDONE
    ALLDONE
    sure there is, the plywood floor has about a 4 x 6 hole that you can barely hook up the cables and you can only see 2 caps..... that what I went out to check to make sure.... thats when I seen only 3 caps, and went to get a flash light... then I clearly read 6 volts.... so in my life I have still never seen an eight volt battery... but sure they exist
  16. ALLDONE
    ALLDONE
    what??? it doesn't say I own any thing,,, it say how do you charge a 8v battery....you should go with me to the eye doc....2 for 1 deal...
  17. ALLDONE
    ALLDONE
    my good shop type charger is auto matic.... it identified the battery as 6v .put a 2mp 12v and it charged to 7.4 and went to trickle
  18. patsurf
    patsurf
    sorry-was thinking you had some 'shops ' and 'boys' around vegas area--mistook what you were meaning!....
  19. chickenridgerods
    chickenridgerods
    from DSM, IA
    Ford had a V8 in 1932. Why did they wait for 20+ years?
    Cars kept adding electrical equipment. Radios. Lights. Wipers. Gauges. What's required to run all that stuff? Power. What's the formula for power? Voltage * Current. What drives wire and terminal contact sizes? Current. How do you reduce the current in order to keep those sizes down? By increasing voltage.
    My day job is as an electrical engineer who designs electrical systems and wiring harness for industrial equipment with far greater electrical demands than any vintage vehicle. What sort of electrical engineering do you do?
    An 8V battery in a system that was adequately designed for 6V is a BAND AID. Especially so if the damn charging system isn't changed accordingly.
    twenty8 likes this.
  20. chickenridgerods
    chickenridgerods
    from DSM, IA
    I read the thread. You didn't post the text quoted below? That certainly makes it seem like you have a car with an 8V battery.
  21. ALLDONE
    ALLDONE
    this was a pretty simple thread
    first post; how do you charge an 8 volt battery...
    second post; with an 8v charger...
    thread done.... how it got to VW wiring was what called evolution...
    most of the rest has been clever ways to come at "ALLDONE" TO TRY TO GET UNDER HIS SKIN AND GET A ROAR FROM THE OTHER DING DONGS THAT THINK IT'S COOL... going from me admitting I miss read, to me not being able to do anything. not knowing anything, and not knowing how to run a 40yr in business shop is pare for this site and why every body I talk to in vegas says the same thing... I read the stuff there but never post...the trolls attack everybody not in their circle...you guys don't bother me , lots of good help and advise,... thats the honey of this place... lots of angry BEE'S thou.....
    42merc and firstinsteele like this.
  22. patsurf
    patsurf
    sorry you are upset--but now i 'understand how i didn't understand ' you having a shop!
    ALLDONE likes this.
  23. ALLDONE
    ALLDONE
    no upset at all...
