wiw 48 plymouth
Discussion in 'The Hokey Ass Message Board' started by moparted, Sep 22, 2009.
  1. moparted
    moparted
    from upstate ny
    info from seller"
    REBUILT SWEET RUNNING 330 C.I. "HEMI"
    VINTAGE EDELBROCK INTAKE MANIFOLD
    EDELBROCK 4 BL. CARB
    BILLET PULLEYS
    CHROME ALTERNATOR
    CAST ALUMINUM VALLEY PAN
    "NEW" MSD DISTRIBUTOR AND COIL
    "NEW" HIGH PERFORMANCE PLUG WIRES
    WEIAND WATER PUMP
    STAINLESS FLEX HOSE COVERINGS
    ELECTRIC COOLING FAN
    ELECTRIC FUEL PUMP
    NEW COATED HEADERS
    ALL "NEW" DUAL EXHAUST WITH "H" BALANCER PIPE, hEAT SHEILDS IN CRUCIAL AREAS, CHERRY BOMB MUFFLERS, 4" STAINLESS EXHAUST TIPS.
    REBUILT TORQUE FLITE, AUTO TRANS WITH A MILD SHIFT KIT
    "NEW" TALL LOKAR FLOOR SHIFTER
    12 BOLT REAR, NON POSI
    bODY AND SUSPENTION DETAILS:
    THIS IS A RARE BUISNESS COUPE WITH NO BACK SEAT AND THE SHORT 1/4 WINDOWS.
    VERY SOLID BODY
    THE CAR IS PAINTED PPG # 61303 STREET ROD COLORS "SHERBET PEARL" (NOTE: THE PICTURES WERE TAKEN IN THE SUN SO COLOR MAY LOOK A LITTLE PINKISH IN SOME PICS)TRUE COLOR IS MORE OF A CORAL OR APRICOT.
    THE HOOD WAS SHAVED AN FILLED
    THE DECK LID WAS SHORTENED AND THE REAR BODY PANEL LENGTHENDED
    "NEW " PONTIAC LED TAILAMPS
    "NEW" HALOGEN BRITE LIGHT HEADLAMPS
    V BUTT WINSHIELD WITH NEW SEAL, ALL OTHER GLASS IS NEW GRAY TINTED
    OPERATING COWL VENT
    "NEW" NOS OUTSIDE DOOR HANDLES
    INSIDE HOOD AND TRUNK RELEASES
    "NEW" DOOR PANELS, CUSTOM WINDOW AND DOOR HANDLES
    TILT STEERING COLUMN
    NEW WIRING HARNESS, ALL ELECTRONICS OPERATE.
    POWER STEERING
    RECESSED STAINLESS STEEL FIREWALL
  2. moparted
    moparted
    from upstate ny
    three pics
  3. moparted
    moparted
    from upstate ny
    there are more pics if needed
    i am thinking of buying it
  4. TexasHardcore
    TexasHardcore
    from Austin-ish
  5. moparted
    moparted
    from upstate ny
    all the info i got earlier was deleted.
  6. moparted
    moparted
    from upstate ny
    is it worth 10K??
  7. moparted
    moparted
    from upstate ny
    guess not. still hoping to find a mopar powered . mopar bodied, street rod
  8. moparted
    moparted
    from upstate ny
    it didnt sell
  9. It's worth what YOU and the SELLER agree to.
  10. John Denich
    John Denich
    Its not worth ten grand to me....but if you like it who cares what its worth!!!!
  11. Fenders
    Fenders
    What's it worth to YOU? Offer him that.
  12. it's probably worth 10k, but lose the pink, corral, apricot color, geeeeeezzz!
  13. moparted
    moparted
    from upstate ny
    i offered 7500 and was turned down
  14. moparted
    moparted
    from upstate ny
    is anyone griving such a car with the factory front drums?
    how bad are they?
  15. James Curl
    James Curl
    If you have the correct acme tool to adjust the shoes with the drums off to fit within .003 of the inside diameter of the drums then the thing will stop fair. If you adjust by feel then it will be long stops. I have replaced mine with disc on the front and a 90 Dakota rear so I now have modern brakes, not power so they take some force to stop short. The original are sufficent for a flathead six powered car but I would replace them on a V8 powered car. Every time the brakes need to be adjusted all four drums must come off to use the acme adjuster which can be a real chore.
  16. moparted
    moparted
    from upstate ny
    what did you use for the front disks?
  17. James Curl
    James Curl
    I have one setup from PlyDo and another setup from Rusty Hope or Old Daddy, I believe that he is a member here on the forum. They both use MoPar rotors with chevy calipers and their 3/8" steel bracket to adapt them to the Plymouth spindles. I am using the ones from old daddy on my car now but will replace them with a set of Fat Man dropped uprights with the PlyDo disc setup I bought with A frames after I buy and Install a rebuild kit for the front suspension.
  18. moparted
    moparted
    from upstate ny
    any pics of you car?
  19. moparted
    moparted
    from upstate ny
    spoke to car owner, he wont take less than 9950, too much for me
