I'm trying to get my wolf whistle hooked up to my 53 desoto and I'm having some difficulties. It probably wouldn't be so bad if my local auto parts shops weren't so pathetic. Does this look right? I'm hoping to find the right pieces I need online. Any ideas on these sizes?
Ya that should work. F&j the whistle pulls air past a nozzle and makes noise kind of like a reverse effect of blowing air over a bottle
dedicate a manifold port drill/tap a new one rather than leaching off a brakes booster use all hard line /pipe as hoses will collapse ... having a straght pull for your cord is best stretched tight...... a taught line to pull sideways works best
So here's what I came up with. Testing <iframe width="560" height="349" src="http://www.youtube.com/embed/7v9VkVC759g" frameborder="0" allowfullscreen></iframe> Installation. Made an L bracket, bought some chain for the pull. The 2" br*** extension/ball check valve broke (I had to JB Weld them together), so I subs***uted a piece of galvanized for now. I cut a piece of flared brake line to stick in the firewall for the chain. Istill have to make a mount under the heater control for the end of the pull chain. I need to replace my 3/8" male/3/8" female ball check fitting for the vacuum... anyone know a source?
Here is our install and the boys trying to master it: <iframe width="480" height="390" src="http://www.youtube.com/embed/eV08lLL7o2k?rel=0" frameborder="0" allowfullscreen></iframe>
Hey, that's cool! I should hook up one of the two i have up in the cabinet...OK, it's on the 2 do list...
