Won at the auction tonight! (now what???)
Discussion in 'The Hokey Ass Message Board' started by chopped51, Feb 2, 2012.
  1. gump
    gump
    Do you mind sharing what the winning bid was. I think it is cool.
  2. Mr48chev
    Hell, it will probably start and run with very little effort. I think I'd get it running, clean the cab up a bit and build a flatbed for the back and have a shop truck to boogie around in until someone else fell in love with it. You can probably do an axle shaft swap in the back to get five lug if needed but I wouldn't get too excited about that right away as someone spent some good money on having the driveshaft done.
  3. 31Dodger
    31Dodger
    The Plymouth, Chrysler and DeSoto had the same body in 1930.
  4. 31Dodger
    31Dodger
    Get yourself a Chrysler 8 3/4 rear and drive it.
  5. RichG
    RichG
    I'm going to guess '28-9 Plymouth truck.
  6. DJLATIN
    DJLATIN
  7. Seepwater
    Seepwater
    That isn't a N case...it looks like a WAR casting (no notches on the cross ribs).
  8. Blacktop Graffiti
    Blacktop Graffiti
  9. I think there is serious potential there.
    Minus the engine ,that is.
  10. 38Chevy454
    38Chevy454
    The engine is probably a 2.8 out of an S-10, and the rearend sure looks like an 8-inch. Not a 9-inch being flat on the top, and the center section looks like 8-inch with the ribs. The 4-lug you could probably just get another 8-inch out of any Ford small block powered car and be an easy swap. What is the front bolt pattern and brakes?
    I would just try to clean the metal to get the rust off, spray bomb it with some epoxy primer and then flat paint after minimal body work. Build a flatbed for the back. Run that engine unless you have a cheap donor V8 to use, just keep the hood closed. Fun truck to cruise around and ***uming you got it for cheap, I bet you can have fun and make money on it when you do sell later.
  11. hotroddon
    hotroddon
    So did Mustang 6 cylinders
  12. czuch
    czuch
    from vail az
    I'd say you won. No matter what it is. Get it runnin and cruise it.
  13. 55chevr
    55chevr
    What transmission does it have in it?
    Joe
  14. redlinetoys
    redlinetoys
    from Midwest
    Kind of neat, really!
  15. Brad54
    Brad54
    from Atl Ga
    It looks like they did a pretty good job converting it to a 2dr pick-up cab. Thru the windows, it looks like the rear of the cab was installed nicely.
    The driveshaft is brand new. The rear end looks like someone at least took the time to rattle-can it black, along with the leaf springs. The busted clamp on the rear half of the p***enger side spring could mean they actually took the time to take it apart to clean it up.
    If anything, maybe convert the rear to 5-lug, but there's no reason to get rid of the 8-inch, especially if that new driveshaft has a new rear u-joint in it.
  16. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Looks like an excellent foundation for a hot rod. REALLY nice foundation, actually. It would be unique, that's for sure.
  17. Got a 9" in my 48 with a flat top, one way to tell if it has the lower bolt that you have to use a wrench on!
  18. HotRodderDaughter
    HotRodderDaughter
    from San Diego
    looks like a fun project!
  19. Shopking
    Shopking
    from central Pa
    I hate those suprise winning bids.(came home with a dump truck years ago) But this looks like a lot of cool potential.
  20. 57 Fargo
    57 Fargo
    I want it!! That's cool as hell!
  21. Boyd Who
    Boyd Who
    That's pretty cool!
  22. V8 Mustang II is my bet. They could come in TrackLok too. They are worth a few $$ as they are rare if it is.
  23. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Its a 30 to 31 Model A pickup .Nice start ...Im trying to figure out what chevy six cylinder it is...8 inch or 9 inch ford is a given,I cant make out if it has the extra rib,I think its a nine
  24. uncle buck
    uncle buck
    Its not even a 9" for that matter. It is a 8" possibly out of a Mustang II / Pinto or Maverick with it being a 4 lug unit
  25. RAG66
    RAG66
    from WASHINGTON
    Is anyone reading the other posts or just posting to increase your post count. It has been determined to be a 30-31 sedan body that was shortened. Some people, read the thread!!!:eek:
  26. Bad when you don't look at the visor, the cowl, the grille, or the next few posts down very close. Already ID'ed as a Chrysler. Should have a tag, or holes where a tag was, on the right doorjam, cowl side.
  27. modeleh
    modeleh
    You're car crazy on the same level as Barry Mcquire.
  28. 55 dude
    55 dude
    get it runing and put it on craigslist!
  29. todztoyz
    todztoyz
    Good one!
  30. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Yes I am,,,,,But Im normal.......It was late I was tired ,Didnt even look at the 4 lugs anyway He has a nice start ,Ive started with less .....
