Wondering about this buy?
Discussion in 'The Hokey Ass Message Board' started by tapkoote, Aug 15, 2013.
  1. tapkoote
    tapkoote
    49 chev w/sbc-tb 350
    Over heating problem in hot weather stop & go traffic.
    It's got the original 2 row radiator from the 6 cyl auto. Don't mind replacing the rad is there some thing else I'm missing?:confused:
  2. gimpyshotrods
    gimpyshotrods
  3. Shaggy
    Shaggy
    from Sultan, WA
    Timing, timing, timing.....
  4. tapkoote
    tapkoote
    yes there's a little fan in a big shroud.
    The car starts right up and runs OK, doesn't sound like timing.
    Thanks for the help
    Pat
    will check it out again tomorrow. Hoping it's nothing like head gaskets, didn't look in the rad.
  5. VoodooTwin
    VoodooTwin
    from Noo Yawk
    A rad swap to one with bigger capacity is a good investment. Post a few pictures of your current fan/shroud/rad setup so we can help diagnose. Is your tstat working as it should?
  6. 40fordtudor
    40fordtudor
    Is the "little" fan electric?? Is it operated by a thermo-switch?? What temp range on the thermostat?? A 195/170 thermo switch might help if the thermostat is not faulty. Run it thru a relay a toggle won't handle the load I don't think.
  7. Heck, is the fan even working at all? If it's a clutch fan, sometimes they break in a way you can't really see while it's going - it still spins, just not enough.
    That stock '49 radiator is only good for about 6 lbs of pressure, too. Much more and you'll split a tank or worse.
  8. 50 customcoupe
    50 customcoupe
    Hi, I have a '50 chevy coupe with a '64 283 with stock water pump and 4 blade fan, no shroud, fan to close to rad. Car runs cool all of the time with stock '50 rad. How big is your fan ????
  9. tapkoote
    tapkoote
    I don't have the car, looked at it last night to buy.
    It's got an aluminum flex fan. Looks 2 inches short of the shroud dia.
  10. MATACONCEPTS
    MATACONCEPTS
    Sounds Fixable. Plus your on the HAMB. We got you. Buy it broken for a great deal. SBC should NOT start RIGHT up, It should crank a little when properly timed. The HAMB could figure out anything.
  11. Throw the flex fan away and get a real one!
  12. HOTRODPRIMER
    HOTRODPRIMER
    Flex fans are not efficient,,try a good steel bladed fan,it will make a lot of difference. HRP
  13. DaPeach
    DaPeach
    from NE OH
    this & it's probably too small to be sufficient.
    I've got one hanging on the wall because it caused the same problem, changed it & it was fine since.
  14. Dane
    Dane
    from Soquel, CA
    Your making a big mistake not checking timing 1st. Why spend time and $ when a simple turn of the dist might cure the problem?
  15. tapkoote
    tapkoote
    I'm going to go ahead and get it, after checking for oil in the rad. and burnt trany fluid.
    You're right it'll only take a minute to check the timing.
    And it does have one of those old black caps with the ears,
    must be low pressure cooling, I plan on a bigger rad and fan.
    Thanks guys
  16. ironandsteele
    ironandsteele
    This.
  17. tapkoote
    tapkoote
    Timing is every thing!
    Got a light on it --8 degrees past top dead center.
    I can't imagine how it even ran.
    I got it at 4 * right now, don't know the spec.
    It fires right up like a ford, so it may not be right yet.
    Hope that knocks some temp out of it, but I thought retarded would make it run cold.
  18. 2racer
    2racer
    hot weather in seattle?
  19. arkiehotrods
    arkiehotrods
    Retarded timing generally makes an engine run hotter
    Check out post #7 here
    http://www.hotrodders.com/forum/timing-overheating-160577.html
  20. tapkoote
    tapkoote
  21. Hemirrhoid
    Hemirrhoid
    from Wisconsin
    Had a similar issue - head gasket!
  22. tapkoote
    tapkoote
    it all relative- you know the joke about relative humidity;)
  23. 2racer
    2racer
    had to look it up,
    relative humidity- when the sweat off your balls drips down the ....
  24. tapkoote
    tapkoote
    It's got something to do with your sister-inlaw.;)
  25. sport fury
    sport fury
    a bad radiator cap or a vacuum leak could also be a problem with over heating.
