Wood Floors In A Sedan
Discussion in 'The Hokey Ass Message Board' started by jumbogem29, Mar 10, 2013.
  1. jumbogem29
    jumbogem29
    from Alabama
    Has any one ever used the wood floor kit from Mac's or Snyder's thinking of putting wood back in my sedan wood like to see some floors you have done trying to get some ideas i think it would be cool thats the way old henery used to. Does anybody else make a wood kit that fits. I think they came with oak when they were built lets see what you got.
  2. HOTRODPRIMER
    HOTRODPRIMER
    If you are going to use wood make your own floors. HRP
  3. J'st Wandering
    J'st Wandering
    They are 1" boards ran from one subframe to the other. On the bottom side they had a couple of 1" by 2" boards ran across the boards to hold them together, as I remember. Maybe someone will shoot you a picture or two.
    I took a piece of 1/2 inch plywood and made a floor. I have an original floor stored away. I would not spend the money on buying a kit, just go to the lumberyard and buy the kind of wood you want.
    Neal
  4. Racer29
    Racer29
    I built mine with some free plywood. Covered them up with a rubber mat and no one ever knows the difference.
  5. T&A Flathead
    T&A Flathead
    I used treated plywood then added additional water sealer and covered it with rubber matting from macs.
  6. tommy
    tommy
    Cheaper and better than steel which requires expensive sound deadener and a rust preventer. We are talking about nostalgic cars and not modern streetrods right? I made my own due to the recessed fire wall.
  7. jumbogem29
    jumbogem29
    from Alabama
    There they are coming out of the wood works.
  8. motoandy
    motoandy
    from MB, SC
    I used marine grade plywood in my former model a. Cheap and easy to install and remove if need be. Once covered with carpet who knows?
  9. HOTRODPRIMER
    HOTRODPRIMER
    Same thing I did with my old Model A pickup. HRP
  10. jstanotheidiot
    jstanotheidiot
    Hay I think they grow on Tree's
    Ford used old crate's as to not have to buy wood
