Projects Wood or metal?
Discussion in 'Traditional Hot Rods' started by Nibsy30, Aug 23, 2016.
  1. Nibsy30
    Nibsy30
    from Trail BC
    This is my first old school hot rod build just wondering if I should replace the wood in my 1930 A coupe with wood or make it with metal ?
  2. squirrel
    Probably depends on what condition the wood is in, eh?
  3. gimpyshotrods
    gimpyshotrods
    How are your wood welding skills?
  4. Barn Find
    Barn Find
    from Missouri
    You should be able to buy the wood for a Model A, so just do that and be done with it.
  5. mgtstumpy
    mgtstumpy
    I retained the wood in my 35 Chevy and replaced a few pieces. However I fabricated a fairly stout ch***is to maintain some integrity and stop a lot of body movement and flex. Been on the road many years now without issue
  6. robtlor
    robtlor
    from Lincoln NE
    tb33anda3rd and mgtstumpy like this.
  7. Nibsy30
    Nibsy30
    from Trail BC
    The wood is in bad shape and my wood welding skills are poor
  8. kevinwalshe
    kevinwalshe
    Buy a wood kit, sand paper, file/rasp, and you'll be golden. It's pretty straight forward but will take some m***aging to get it to fit right. You'll save time and money in the long run. I have some Model A body wood I'd like to get rid of, used but not destroyed. PM me for info.
    Hudson31 likes this.
  9. movin/on
    movin/on
    If I remember correctly most of the wood in 1930 Coupes was for interior mounting, not structural. 4 door Sedans by Briggs had a lot of structural wood. Murray Bodies not so much. How about a picture of the wood in question.
    Movin/on
  10. N2hotrods
    N2hotrods
    Use wood. There are many suppliers such as tams model A. The wood let you have a base to install the interior and the garnish moldings. If you plan on using an original top you will want the wood for a nailing base.
  11. Dino 64
    Dino 64
    from Virginia
  12. Nibsy30
    Nibsy30
    from Trail BC
    Thanks for the info. I'm filling the roof i want the smooth look
  13. Nibsy30
    Nibsy30
    from Trail BC
    I guess I should figure out and start a build thread and put up some pics
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I guess I'm the minority here. When I build a hot rod I replace all the wood with metal - except maybe the gear shift ball. I like the permanence and additional structural rigidity the steel adds.
