1952-59 Ford Work on my 54
Discussion in 'Off Topic Hot Rods & Customs' started by orangedog, Aug 17, 2021.
  1. orangedog
    orangedog
    I hope I'll continue to be able to receive your help and knowledge on this group. My current plans are to repair floor pan, install sound/insulation to the floors and install my Vintage Air ac. Then replace the carpet. Then I want to drive sumor. Don't beat me too much on my welding, this is my learning project for sheet metal.
    20210626_130056.jpg 20210715_154716.jpg 20210715_154841.jpg 20210702_165925.jpg 20210811_151254.jpg 20210814_173015.jpg
  2. evintho
    evintho
    Forward progress is a good thing! As far as welding, we all had to learn sometime. I learned through trial and error on my roadster. Just make sure the metal you're welding to is sound. Also, grind all the rust down to bare metal on your surrounding metal. Tack every inch or so, let it cool, then do it again, and again, and again.
    JeffB2 likes this.
  3. orangedog
    orangedog
    Thanks evintho. I've watch many on youtube that make welding sheetmetal look easy. Didn't get to do much on the car today, cut out a small patch for the side panel at the at the toeboard/floor patch.
    JeffB2 and Dos Cincos like this.
  4. Dos Cincos
    Dos Cincos
    Small progress is still progress and one less item to be completed on the list.
  5. okiedokie
    okiedokie
    from Ok
    For me it has always been important to achieve something on the current project each day, no matter how small. Your progress looks good.
    56longroof and guthriesmith like this.
  6. nosford
    nosford
    Welding on floors is a great place to learn, as long as it is stuck down solid you can grind away, cover it up and no one is going to see it! My friend always says the difference between a good welder and a great welder is a good grinder. Carry on!
  7. orangedog
    orangedog
    Your right nosford, it will all be rust treated, welds primed joint sealed and painted. Only have to please myself. I do have a patch I'm going to take back out, I need to get to some better metal.
    Thanks for the replies.
    56longroof likes this.
  8. orangedog
    orangedog
    It's been slow going but I've gotten a few more patches in. 20211012_155456.jpg
  9. HOTRODPRIMER
    HOTRODPRIMER
    Your work looks good, hang in there, the more you do the better you get, it just takes practice.
    BTW, it looks like you have a pretty solid car, my floors were shot! HRP
    56longroof, JeffB2, ffr1222k and 2 others like this.
  10. orangedog
    orangedog
    HRP you did a great job with yours. In relation to the work you had to do, I can see the light at the end of the tunnel on mine. Thanks for your post.
  11. orangedog
    orangedog
    Well I've gotten the front drivers side floor in. Moving to the rear drivers floor.
    56longroof, JeffB2 and nosford like this.
  12. evintho
    evintho
    Bravo! Lookin' really good! As stated, the more practice you get, the better the finished product. It's definitely coming along!
    mikhett, JeffB2 and orangedog like this.
  13. orangedog
    orangedog
    Made 3 more patches. I plan to weld them in tomorrow.
    JeffB2, nosford and 56longroof like this.
  14. orangedog
    orangedog
    I welded in the last 3 small panels, and a couple more. Time to fab up a cover for large hole left back there. Heading out on a camping trip Friday, so I won't get to far on that cover for a week.
    56longroof, JeffB2 and Dos Cincos like this.
  15. orangedog
    orangedog
    I can't believe how long it's been since I posted. I had other priorities take over after our trip. I've put in a few more patches and have a coat of rust sealer on the floors. I thought I was through patching for a while until I saw some holes where the front of the rear wheel well meets the floor. I'll fix that in-between seam sealing and painting with Por 15. I also took out the bracket for the pull strap and beefed that area up for my shoulder belt anchor point
    IMG_20220118_164530.jpg IMG_20220202_112832.jpg IMG_20220202_134552.jpg IMG_20220511_101700.jpg IMG_20220511_101836.jpg IMG_20220521_150327.jpg IMG_20220521_150417.jpg IMG_20220527_140529.jpg
    56longroof, JeffB2, 40FORDPU and 4 others like this.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Looks good. HRP
  17. bobss396
    bobss396
    Nice clean work.
  18. orangedog
    orangedog
  19. Dos Cincos
    Dos Cincos
  20. jailbar joe
    jailbar joe
    looks great you have done well....the only problem with welding when you are just starting out is that you weld in a patch and think,that looks okay then by the time you get to the end of the project and your welding has improved immensely you look back at your first attempt and think....i might redo that one.:)
    we have all been there and like me...... still do it:( hahaha
  21. orangedog
    orangedog
    Thanks for the encouragement. It's beginning to brighten up inside. I've gotten the seam sealer done , 2 coats of Por 15 and some insulation in.
    JeffB2, 56longroof, nosford and 2 others like this.
  22. orangedog
    orangedog
    I think this is the last patch related to the interior at least. A little more insulation to finish and I'm about ready to start hanging the A/C.
  23. evintho
    evintho
    Excellent work!
  24. okiedokie
    okiedokie
    from Ok
  25. orangedog
    orangedog
  26. orangedog
    orangedog
    I thought I was ready to start ac install, then remembered some under dash wiring I should do before the condenser unit goes in. Ran some rear (future) speaker wires down the p***enger rocker to the trunk, then remembered a hole in the back side of the rocker I was going to fix later. That's redone now. Hung the condenser to get a idea of where the lines need to go.
  27. Slicks
    Slicks
    from denison tx
    That will sure help keep it nice an cool
  28. Paul2748
    Paul2748
    What did you use for the insulation ?
  29. Texas57
    Texas57
    Not to be picky, but that's the evaporator you hung. The condenser is the radiator-like unit that goes in front of your radiator.
    JeffB2 likes this.
  30. orangedog
    orangedog
    Paul2748 it's a high density foam with foil on both sides. I order it in a 4ft. width.
    Texas57 my oldtimers kicks in more often than not any more, I put it in the correct place, right?
    ffr1222k and JeffB2 like this.
