1952-59 Ford Work on my 54
Discussion in 'Off Topic Hot Rods & Customs' started by orangedog, Aug 17, 2021.
  1. nascardave
    nascardave
    I like the idea of you using a cable for shifting. Can you show a picture of how it is attached to the column under the hood?
  2. orangedog
    orangedog
    This isn't a very good shot. I'll try to remember to get a better one tomorrow. Where the end of the lever going up and to the left get cut off in the picture is where the cable connects, you can just see the edge of the black bushing where the cable attaches. IMG_20220722_151248.jpg
    down-the-road likes this.
  3. orangedog
    orangedog
    This should give you a better idea how the cable runs up to the steering column.
  4. nascardave
    nascardave
    Thank you very much for the pictures. That was a big help. I like what you have done. Was that an over the counter cable or a custom made?
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Have you seen Posts # 149 & 154 in the "Sticky" ?
  6. orangedog
    orangedog
    Nascardave I can't take credit for the setup, the motor and trans had been swapped when I bought the car. I do think it is over the counter. I have seen the cable bracket that bolts to the trans and holds the cable on a website, I think it was a BM product.
  7. nascardave
    nascardave
    Orangedog, Thank you for the info. JeffB2, Thank you for the info. also.
    JeffB2 likes this.
  8. orangedog
    orangedog
    Wow I didn't realize it has been so long since I did anything post worthy.
    My rear end has made noise since I bought it. I thought about the ranger rear end but decided to check out mine. I pulled the axles and the differential. I decided to replace all the bearings and run it a while longer. Below is a list of the parts used, followed by a few pictures. I hope this will help someone.
    Differential gasket – 8A-4035-C Shoebox Central
    Pinion Seal - 8A-4676 Shoebox Central
    Pinion bearing - Timken 02876 cup Timken 02820
    Timken 31597 cup Timken 31520
    Pinion Bearing Spacer – 8A-4662-B Ebay
    Differential bearings - Timken 24780 cup Timken 24720 / 2
    Rear Axle Bearings – Timken 88107AR
    Axle seal – National 450444 / 2 O'Reillys
    Axle Flange Gasket – FelPro - #FPG 55001
    Backing Plate to Housing Gasket - Shoebox Central
    Driveline Yoke seal saver - Speedi-Sleeve # NOS 99162 - NAPA
    All bearing from Ebay
  9. Fairlane 62
    Fairlane 62
    So do you have a quiet rear end now?
    JeffB2 and down-the-road like this.
  10. orangedog
    orangedog
    Yes it is quiet and now I'm not afraid to expand my driving radius.
