1952-59 Ford Working on the '59
Discussion in 'Off Topic Hot Rods & Customs' started by bobss396, Aug 25, 2014.
  1. bobss396
    bobss396
    I wound up having to slot the shock holes. The spread on the '59 lower arm was wider than the holes on the 5821 Sensa-Trac shock. This is the "after" shot. Took like 5 minutes per shock. They went up okay but I used bigger washers, with some luck they'll hold.
  2. koolmercuryman
    koolmercuryman
    from iowa
    looking at all these pictures reminds me just how much work goes into bring a car back to driving condition.
    mikhett likes this.
  3. Texas57
    Texas57
    Bob...I think there is always interest in other guy's builds...that's why we're all here! I think most just don't want to keep posting the "looking good" replies to keep the threads from getting cluttered.
    BTW...Looking Good!, you do need to get that Bridgeport cleaned up though!
  4. bobss396
    bobss396
    Yeah, the Bridgeport is a mess lately... I need a new DRO for it otherwise I'd use it more. I also have a Clausing lathe to get up and running. I'll keep posting pix as I go.
  5. bobss396
    bobss396
    0927141811a.jpg 0927141811.jpg 0927141811b.jpg 0928141758.jpg More work this weekend. Disc conversion is done, master, proportioning valve & lines are next. Car looks good sitting on all fours.
    1954vicky likes this.
  6. Rui
    Rui
    Very nice.
  7. bobss396
    bobss396
    Got the 4-speed & Hurst shifter bolted together on Sunday.
  8. Rui
    Rui
    Wow! Good lookin industrial scented piece.
  9. bobss396
    bobss396
    1005141703.jpg Another shot of it on the shelf waiting.
  10. Rui
    Rui
    They say that beauty depends on the eyes of the beholder. Maybe my mind is a bit distorted, but I consider these kind of parts auto-beauty!
  11. bobss396
    bobss396
    Got the brake & clutch master bracket made up last night. 1/4" thick 6061-T6 aluminum plate. The thing on the floor behind it is the cat... she knows that kitchen = possible food...
  12. bobss396
    bobss396
    0927141831a.jpg 0927141832.jpg Made up a bracket to mount up the proportioning valve to the inner fender. This and the master bracket just went out for alodine this morning.
  13. bobss396
    bobss396
    1129141350a.jpg The car is finally under cover for the winter.... a tad tight but still arranging things.
  14. bobss396
    bobss396
    1128141314.jpg Unearthed the 350 as well. Been sitting since 1984 and still turns.. hot dog!
  15. bobss396
    bobss396
    More work done over the holidays. Borrowed a ***y hydraulic flaring tool which made things easier. All the lines came from NAPA and went in without a major struggle. Wound up making a new brake & clutch master bracket to give the clutch master a little more room & strengthen it up. I'll get some better pix over the weekend. 1229141608.jpg 1229141608.jpg 1231141119.jpg
  16. bobss396
    bobss396
    Got the battery tray in, had to mill off the mounting flanges so it would fit in the stock location.
  17. Rui
    Rui
    Looks good.
    How will the bat fix in place?
  18. danman55
    danman55
    I like the looks of that hydraulic flaring tool... do you have a brand name or an tool number? Surely that didnt' come from China Freight lol!!!
  19. bobss396
    bobss396
  20. 55Brodie
    55Brodie
    Very ***iful....high speed, low drag!
  21. bobss396
    bobss396
    Got my wiring kit the other day from Kwik Wire... looks a bit intimidating but the instructions look good and everything is labeled.
  22. JeffB2
    JeffB2
    from Phoenix,AZ
    Now you can sell it and get a good Ford motor! Right? :rolleyes:
  23. bobss396
    bobss396
    I'm using what I have around the shop. It would cost me maybe $5000 more to scare up all the parts I needed to go with a 351 or 429. I looked at a BOSS 351, but it was a basket case, all apart and has been sitting outside in the rain.
    I saw on the HAMB where one guy that did a similar swap referred to the Chevy engine as his a-hole detector which I agree with.
  24. JeffB2
    JeffB2
    from Phoenix,AZ
  25. bobss396
    bobss396
    I would have to go through it completely, my engine I know in & out. The plan is to eventually drop a 351/429/460 into the Ford and swap the Chevy parts into a '66ish Nova.
  26. bobss396
    bobss396
    Located the tach to the steering column, made up a bracket which is out for alodine.
  27. bobss396
    bobss396
    Made up a mount for the harness fuse panel, may or may not use the standoffs to raise it up. ****py picture was taken at the bar, showing off the part to my homies.
  28. bobss396
    bobss396
    Windshield is out, getting it ready for the new one. Primed and have to do some sealer in a few places. Gauge panel is stripped down, getting ready for the re-wire job.
  29. Rui
    Rui
    Good wise job.
  30. bobss396
    bobss396
    I never intended to take the car down so far. But one thing leads to another. My gl*** guy was over a couple of weeks ago, picked up my window gl*** to do at his shop. He had a few good suggestions regarding the windshield and considerations since I'm going to be painting the car in the future.
