1952-59 Ford Worn out starter drive or something else?
Discussion in 'Off Topic Hot Rods & Customs' started by 1954vicky, Jun 3, 2011.
  1. 1954vicky
    1954vicky
    from Reno, NV
    So I'm converting the 54 to 12v and yesterday I got everything hooked up and wired up. I tried starting it and it will turn over, but about the time it wants to fire it sounds like the starter disengages and just spins. I tried half a dozen times and got the same thing every time. So does this mean the starter drive is worn out? Or the starter can't take the 12v? It didn't do this before the 12v switch.
    Set up is on a 239 y block with a 1 wire gm alternator, brand new battery and brand new starter solenoid.
  2. sircampsalot2
    sircampsalot2
    I looked it up on line (from your explanation of symptoms) and from what Ive read they say it could be a starter solenoid going bad....
  3. 1954vicky
    1954vicky
    from Reno, NV
    You probably read the same sites I did! I've put two different solenoids on it with the same results.
  4. flyboy89
    flyboy89
    from So. Cal.
    Sounds like the starter drive to me. The spring on the drive could be weak or broken. You may have to remove the starter and replace the drive gear ***embly.
  5. Ole don
    Ole don
    Its the starter drive. This is a good time to take the starter to an independent rebuilder, and do not take an exchange.
  6. fordsbyjay
    fordsbyjay
    from Lafayette
    It is the starter drive.
  7. 1954vicky
    1954vicky
    from Reno, NV
    Thanks guys! I'll pull it next week and see if I can find a local rebuilder to get it rebuilt and wired for 12v. So far the cheapest I have seen the starter drive is $42 from C&G. Anyone know of a better deal?
  8. JeffB2
    JeffB2
    from Phoenix,AZ
  9. 1954vicky
    1954vicky
    from Reno, NV
  10. fordsbyjay
    fordsbyjay
    from Lafayette
    Wow, last time I bought a starter drive they were like 12 bucks.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    Yeah,kind of outrageous what these starters go for, Advanced Auto list the drives for $84 and Obsolete Ford gets $199 for a starter without the drive which there is no listing for.I hooked dragonknucks up with a good starter for an 18 pack of PBR last year.
  12. dragonknucks
    dragonknucks
    And its still kickin strong! Best deal I ever made. Even got to hang out and hear some awesome stories. Good times.
  13. FlatHat
    FlatHat
    Do yourself a favor and call Vern Davidson. He rebuilds and converts flathead starters, and the man is a genius.
    Vern's Ford Flathead Shop
    3478-1/2 F Rd
    Clifton, Colorado 81520
    970-434-898
  14. 1954vicky
    1954vicky
    from Reno, NV
    Ok, next dumb *** question... how the hell do I drop the starter out? I got it unbolted and fought with it until my shoulder gave out trying to get it out. I tried every angle possible and could only get it far enough to just see the spring. Do I need to unbolt the idler arm bracket from the frame? I have never done that. Do I need to know anything special about doing that? I've got the car on ramps right now.
    Sorry for the dumb *** question, but I am at a total loss.
  15. 1954vicky
    1954vicky
    from Reno, NV
    Any suggestions? I'm going to head over there tonight to work on it and really like to get this beast out!
  16. raceron1120
    raceron1120
    I don't know about a '54 but haven't had any trouble removing the starter from a '56 292.
    Service manual is vague - it only says "...may be necessary to tilt the starter slightly, to allow the drive to clear flywheel..." Not much help, you've probably alreadry tried that!
    Hoping someone else can offer better advice.
  17. 1954vicky
    1954vicky
    from Reno, NV
    Tilted, twisted, pushed, pulled and cursed - no luck. Thanks raceron!
  18. 1954vicky
    1954vicky
    from Reno, NV
    Unbolting the idler arm bracket is the trick! Less than 5 minutes and that thing was birthed like a greasy, ugly baby. :)
  19. 1954vicky
    1954vicky
    from Reno, NV
    Thanks for the information FlatHat. I had Vern build me a new 12v starter. It didn't change the state of things though. Still no start...
