Worst tech ever: Model A column drop
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Oct 3, 2011.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    Start with this stuff:
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    Use this stuff:
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Make this thing:
  4. milwscruffy
    milwscruffy
    Okay so far I'm with you but, is that a new or used sharpie? I'd say a couple hours invested in that.
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    ...please excuse the undersized temporary hardware. (also need to cut a piece of cork or rubber to go around the column)
  6. Never2low
    Never2low
    No argument here.:p Looks good thou.:)
  7. iwanaflattie
    iwanaflattie
    Is tat stainless steel??
    I had enough hard time drilling a 1/4" hole in a 1/8'' thick piece of ss.
    I didnt use carbide tho.
    Looks good
  8. 55 dude
    55 dude
    for something to go around column take a piece of soft hose and split it.
  9. general gow
    general gow
    MODERATOR
    kev, that's pretty neato.
  10. OldTC
    OldTC
    I love it,......clean simple and easy to understand.
    No superfluous info.
  11. Looks good. I see you cleaned the blood off for the pics.
  12. tiredford
    tiredford
    from Mo.
    Kinda has a billit look to it. Maybe paint it. JMO
  13. dirtbag13
    dirtbag13
    i dig it ! what did you use to engine turn it ? looks like some sort of fitting in the press w a little foam cushion and what grit sandpaper ? i ***ume you used the angle iron for a fence to keep your pattern straight
  14. oldrelics
    oldrelics
    from Calgary
    needs speed holes....?
  15. Kevin,
    That came out pretty slick. If you would have called i have an old nitro rod you could have had. :)
    I like it anyway. Lots of patience involved apart from the vision and skill.
  16. hotrd32
    hotrd32
    from WA
    Should we wear gloves?.....:D
  17. BJR
    BJR
    I'd loose the wing nuts though, looks like they are just waiting to tear your leg open. Otherwise looks great.
  18. jipp
    jipp
    gloves, blah.. i cut my finger in half and a glove may or may not of helped. hah. but then i was in the kitchen.. naw, no gloves :D
    chris.
  19. Mr48chev
    There you have it. The world's simplest and easiest to follow tech article.
    That should get more than a few brains working overtime to build that bracket that they have been putting off working on.
    I don't think that looks the least bit like a "billet" item even though it started as a s**** of aluminum. It has that distinct carved out by hand with simple tools look that our granddads may have done back when.
  20. young'n'poor
    young'n'poor
    from Anoka. MN
    That looks sharp! I too am curious what you turned that with...
  21. Ranunculous
    Ranunculous
    That's nice!
    Engine-turning metal is infectious,once you start you can't stop....
  22. Kevin Lee
    Kevin Lee
    Super Moderator
    Again, the hardware is temporary. To clarify, small bolts and wingnuts will be replaced with bigger bolts and acorn nuts.
    The engine turning was done with what I had on hand last night. 200 grit stuck to the top of a bolt with double sided foam tape. (left all of my cratex sticks at a friend's shop)
    And... has a billit look huh? That's your own baggage I guess – not seeing it.
  23. zman
    zman
    from Garner, NC
    Nicely done. Worst tech? Hardly, actually not even close...
    I don't see that at all...
  24. loudpedal
    loudpedal
    from SLC Utah
    Sweet man. You must be fixin' to sit in the car instead of on the car! That's the way I like it.
  25. CAL
    CAL
    from Neosho Mo.
    Looks good......and now stupid question time. Why did you have to drop the column so much?
  26. Slick Willy
    Slick Willy
    Isnt tech week over??:rolleyes:
    I would like to change my vote!:D
  27. general gow
    general gow
    MODERATOR
    i'm guessing he's lowering the seat down pretty good, too.
  28. Kevin Lee
    Kevin Lee
    Super Moderator
    Ding! This is why I'm lowering the column and yes, the seat too.
  29. chaos10meter
    chaos10meter
    from PA.
    Yes definitely, that way if you do cut a finger off it's much easier to find it, and it kinda acts like a sack to carry it to the emergency room and you don't get those silly questions while waiting like what's that , a finger ?
  30. jipp
    jipp
    hah great idea.. i used a dixie cup with ice to put the remains of my finger in it so they could sew they damn thing back together.. laughs.
    also i do not see the billet part either.. looks damn cool to me.
    chris.
