would this work??? little help plz
Discussion in 'The Hokey Ass Message Board' started by Flat Black 60, Jun 12, 2004.
  1. hey, so far you guys have been real helpful and understanding, but now I have another Q: Would a 35 truck cab fit on a Model A frame? It may be a dumb Q, but I have a 35 cab and am looking for a frame to put it on, and to throw my Flathead in. All help is appreciated. FLat BLack
  2. DrJ
    DrJ
    It would fit OVER a Model A frame.
    Are you contemplating a channeled fenderless "hotrod"?
    If so it would go over it but so does a Model A body go over a Model A frame. except for at the firewall it bolts onto outrigger brackets on the frame and the rear cross member is wider than the frame rails.
  3. The Harpoon
    The Harpoon
    Use the front and rear crossmembers from the A frame, maybe the frame horns too(if you are not doing a suicide axle) and do the rest of the frame from square tubing.
  4. bigfive
    bigfive
    from south L.A.
    it will work. just depends on what your gonna do with it. i think i would go with the a frame. they're cheap and easy to find.
