Technical Would you run it? Magnuflux looks bad...
Discussion in 'The Hokey Ass Message Board' started by Hillbilly Werewolf, Feb 2, 2024.
  1. Hillbilly Werewolf
    Hillbilly Werewolf
    Guys,
    I am mid rebuild of a Borg-Warner overdrive to swap into my '48 plymouth.
    I finally got everything apart and clean enough to mag particle inspect. Everything looks OK so far, except the output shaft.
    It looks to have fatigue/stress cracks.
    What would you guys do? Run it as is? Have it shot peened? Try to track down a NOS replacement (likely hard to find)
    Thanks!
    Deuces, tractorguy and chryslerfan55 like this.
  2. Know anyone good with Tig?
    Hillbilly Werewolf likes this.
  3. '29 Gizmo
    '29 Gizmo
    from UK
    Surface cracks in the case hardening. Shot peaning wont touch it. Take a few thou off locally on a grinding machine may clean it up but it may have been like that from new
    warbird1, Deuces, Paulz and 6 others like this.
  4. Hillbilly Werewolf
    Hillbilly Werewolf
    I have some great Tig welders at my work, as well as a small lathe I am allowed to use. No OD grinder though. That is the surface that presses into the rear ball bearing, so it cant bee too undersized.
  5. Mike VV
    Mike VV
    from SoCal
    NO...welding. It WILL break ! Plus to grind, weld, and remachine...it will cost more than a new trans. !!!
    If you will be driving the car in a more "hot rod" fashion, racing stop light to stop light, etc., find a new / different shaft.
    I'm betting it's surface cracks you have. From your pictures, I see no single, deep, or large crack(s).
    If your just cruising around, car shows, doughnuts in the morning, NOT racing your buddies, put it together and drive it.
    Mike
  6. GuyW
    GuyW
    The crack pattern is intriguing and suggestive, but if I mag tested something and got a bad test result I'd trashcan the part - why else would I mag test it??
    porkshop, loudbang and Budget36 like this.
  7. Unkl Ian
    Unkl Ian
  8. Hillbilly Werewolf
    Hillbilly Werewolf
    Unfortunately there are 4 parts in this transmission that are very difficult to find, and this is one of them. I would be happy to trash can it, if there was much of an option for a replacement
  9. Is that magnaflux,,,,,looks like a funny shade of light on it ?
    I have never heard of a shaft cracking like that ,,,,,it’s almost one solid crack .
    Usually the splines will twist first,,,,,they look perfectly straight in the pic .
    Im willing to bet that is a false reading there .
    I would try going over the whole piece with a Scotchbrite pad to remove any buildup of contamination,,,,and test it again .
    Tommy
  10. hepme
    hepme
    U didn't say the engine you have in it. Unless its got some serious torque and you're going to use all of it, just go with the thing. That shaft looked pretty hefty, IMO I'd just go with it.
  11. saltracer219
    saltracer219
    Surface checks from grinding, they won't hurt a damn thing, I would bet that it has been that way since new.
  12. 38Chevy454
    38Chevy454
    I agree that looks like surface cracks from initial manufacturing, during the grinding of the hardened surface. You could confirm using dye penetrant, if very shallow the cracks should not show up much, indicating they are very surface depth.
  13. JD Miller
    JD Miller
    Id Run it . Piece of cake
  14. Hillbilly Werewolf
    Hillbilly Werewolf
    Thanks Tommy. I am not certified to do the NDT at work, just have access to the stuff and 15 minutes of training. I will do as you say, get the part super clean, and grey scotchbrite the area.
    I also can hit it with penitrant dye. May get a different result?
    Equipmentis Magnaflux brand, I am unsure of the brand of the spray. The blue is oil, thisbis the one part I checked that i hadnt put through my degreaser bucket.
    Engine is lightly hotrodded 217 flathead six. A real monster I tell you!
    I do "hot rod" around in it as much as I can, but it is a 95hp engine in a 3200lb car. So....
    I just dont want to get this thing together and break it. I am trying to take the effort to make it the best, bullet proof trans I can. If it was nearly any other part, I would just replace it.
    VANDENPLAS likes this.
  15. Did you Magnuflux it yourself ?
    what crack detetection system did you use ?
    those look like surface cracks , possibly from the hardening process when originally manufactured.
    to see that many cracks I would ***ume a overheat condition ( bad bearing or low fluid )
    I don’t see any other discolouration on the part .
    coukd you p*** by a machine shop and have them put an eye ball on it and confirm YAY OR NEIGH ?
    Tow Truck Tom and Deuces like this.
  16. Slow typing I am . Sheesh .
  17. I would run it. If it had a lateral crack that was several inches long, I would be concerned. Because that was probably run in a low hp. application, I'm having a hard time thinking that is anymore than surface cracks.
  18. BJR
    BJR
    I'd run it, all the while looking for a NOS, or good used one, in case it does break.
    Davesblue50 likes this.
  19. daliant
    daliant
    Do you plan on sending all 95 horsepower through that thing? I'll put my money on a bet that you'll be fine running that thing, as long as the yoke fits tight.
  20. Given the scarcity of replacements, I’d run it and wouldn’t think twice about it. It’s not like you are going to mat the gas and sidestep the clutch.
  21. mad mikey
    mad mikey
  22. winduptoy
    winduptoy
    So it looks like you used a dye penetrant and a UV light
    I think you are seeing the 'fretting' from the inner bearing race that fits against it...or from manufacture when it was surface finished
    I'm inclined to believe isn't anything structural in the shaft.... if it was mine, I'd run it and forget it
    Out of curiosity...clean it real good and repeat the test and see if you get the same pattern
    Deuces and guthriesmith like this.
  23. 6sally6
    6sally6
    From an ex-welder whose seen a LOT of MT tests.....doesn't look like any cracks I've ever seen !!
    Ever heard the phrase....'Swallow an elephant and gag on a gnat ?!'
    You're fretting (see how I worded that !!) over nuth'in. IMHO
    95 HP break that thang?..I thank not. Run it. Drive it normal.
    6sally6
    Tow Truck Tom, winduptoy and Deuces like this.
  24. hepme
    hepme
    Wanna bet it outlasts him??
  25. gene-koning
    gene-koning
    Probably from original machining. The "cracks" are all in line with the ends of each of the spline teeth cuts.
    Hot rodding is all about going fast and breaking parts. I would install that trans, then do my best to break it, so no one else would ever have to be concerned about it. Can't ever recall hearing about the entire end of an input shaft breaking off. Seen some really screwed up splines, and busted gear teeth, but never a broken input shaft.
  26. blue 49
    blue 49
    from Iowa
    It almost looks like there was a bit too much interferance on the press fit of the bearing. Probably been like that since the original ***embly.
    Gary
  27. Hillbilly Werewolf
    Hillbilly Werewolf
    Thanks for all the advice guys. Glad to hear that it is likely a normal condition.
    My plan is to
    clean it better, using grey scotchbrite to brighten the area.
    Re magnuflux it.
    Clean it, dye pen it.
    Check the fit of the bearing.
    Report back.
    Run it.
    To note: the area does not look like it has gotten hot. It is not scored or visibly suspect in any way. The bearing that came off seems perfectly fine, other than a little dirty.
  28. bobscogin
    bobscogin
    Would cryogenic treatment be an option to eliminate any further stresses that may lie below the surface?
  29. dart4forte
    dart4forte
    from Mesa, AZ
    Which trans is this?
