Wow..removing these bones..BIG ONES!!
Discussion in 'The Hokey Ass Message Board' started by 16ozSchlitzMan, Jun 4, 2009.
  1. 48fordnut
    48fordnut
    Tom I couldn't remember the alternate ingrediant. thanks. acetone and trans fluid.
  2. NealinCA
    NealinCA
    It's a 1939 big truck frontend. Whatcha gonna do with those big bones when you get it apart?
    Neal
  3. Neal..going to use them on my rod..or at least try to..will have to bend the perch hangers parallel to each other so I can mount the spring to..overall I'm not sure yet..I got to get the dam things off..are you interested in them..?
  4. Gee...it's been a couple of months...took the summer off..bought a motorbike...been playing all summer...well back at it...the bones are soaking in some acetone and ATF...the pins are still in...will post some info later...stay tuned...see pics below...as you can see the axle was cut...it was bent...junk..
  5. budd
    budd
    torch and a press and they will be out in 15 min's.
  6. revkev6
    revkev6
    from ma
    no they wont. he cut the end of the nut off and left the still threaded taper on it.
    center punch the perch pin and drill it up to about the pin size until you can get the inner tapered part of the nut off.
    another option if you have a good welder is to weld another nut onto what's left of the old one you cut off and put an impact wrench on it.
    then you can put the thing in a press to get the perch pin out.
    if you don't understand what you did, this is a picture of the whole nut, you only cut off the straight sides and left the threaded taper on the perch pin:
  7. Waste of time, listen to Harrison above, just cut the axle and perch through the perch boss, all you will save is the bones anyway.:rolleyes:
  8. G V Gordon
    G V Gordon
    from Enid OK
    Find someone who knows how to run a torch and CAREFULLY whittle the nut away. It takes finess but I have done it on a couple pins that would not budge.
  9. hugh m
    hugh m
    from ct.
    I'd drill through what is left of the taper with maybe a quarter inch drill, and try to spin it out with a drift or cold chisel, then go to a press, if you have one, or use a torch to heat the axle to expand it, and drive the rest of the ****er out.
  10. budd
    budd
    ok i think a 30 ton press would just rip the threads right out of the nut, but if i was going to drill anything it would be the bolt down to where the nut ends and then heat and press, 30 min maybe with the drilling, heating and pressing and your done, on to more fun stuff..lol
  11. Ruiner
    Ruiner
    Oy Vey, what a ***********...rename this thread "How NOT to remove wishbones"...
  12. Little Wing
    Little Wing
    from Northeast
    So um,,what are ya gonna do with em once you get them free :confused:
  13. Just cut the ****in axle and perch bolt outta there, they are trash at this point anyway!
  14. pasadenahotrod
    pasadenahotrod
    from Texas
    This whole operation has been a disaster from day one. The common bolt shoved in the axle instead of the original Ford axle bolt was a good clue to poor maintenance and make-do mechanicing. It is a 39-41 Truck front axle ***embly.
    You wasted a lot of time and effort for nothing.
    One question to any guy who knew anything about early Fords would have stopped you from slicing and dicing and whatever on that junk, or at least pointed you in the RIGHT direction with a knowledgeable picture of what the parts should be and should look like and how they are put together and the fact about the top and bottom tapered seats in the bone knuckles and other trivia like that.
    There are so many front ends from cars and pickups, good usable stuff, I don't know why anyone goes through this nonsense with some junk big truck stuff.
  15. flying clutchman
    flying clutchman
    is the bolt tapered also? the cone nut does not screw into the perch boss correct? if thats correct, then cut off the head of the bolt and press it out the opposite direction
  16. Mr48chev
    The steering arm is welded to the axle to make a trailer axle out of it. That was most likely before it got in the wreck.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  17. Hmmm, wow, all this for that?
  18. Mr48chev
    You can cut through the axle and perch boss with a chopsaw pretty easy if you have someone hold the end of the wishbone. That or a pocket full of cutoff blades in your angle grinder. Cut a slot along each side of the web and knock the center out an the other pieces should come out with a bit of heat and a hammer.
  19. oldtin
    oldtin
    The bones won't fit a normal car or commercial axle, the height of the casting is too big and the perch bolt hole is too large. If you tried hard enough you may be able to adapt the ends to a axle, but that seems like an awful lot of work since regular bones aren't that hard to find.
    I've got a three sets of big truck bones, not much good for anything but a tow bar unless your willing to change the ends out.
  20. I going to s**** them...this thread had lots of great backyard theories...so maybe I'll try to get the backing plates off and the spindles...any ideas!!!!
