Wrist Pin Chart
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Mar 15, 2009.
  1. Little Wing
    Little Wing
    from Northeast
    Kinda odd,anyone know where I can find a wrist pin size chart,,tried goggle but seem to get no where,,figured it could help ID some pistons.
    thanks
  2. gas pumper
    gas pumper
    "Motor's Manual" has pin dia for each make. At the front of eack make's section. You got one of these books? Mine is 61 covers 53-61 cars.
  3. Little Wing
    Little Wing
    from Northeast
    have chiltons will check there thanks
  4. Little Wing
    Little Wing
    from Northeast
    no luck with Chiltons ,,have some like .925..980. 990 ,,1" etc ,,is it referred to as something else? should I be checking for rod end size instead of pin OD ? :confused:
  5. gas pumper
    gas pumper
    It's called wrist pin dia. in my book;
    57-61 Buick .9995
    54-56 Buick .940
    Chevy 348 .9896
    Chevy 6 .8662 or .8647
    Chevy 283 .9271
    Chrysler, all, 55-58 .9842
    Chrysler, all, 59-61 1.0936
    Desoto V-8 53-57 .9217
    Desoto 58-60 1.0935
    Dodge 53-56 V-8 .8592
    Dodge 56-58 V-8 .922
    Dodge 58-61 V-8 1.093
    Ford 54-61 six 272 292 .9121
    Ford 58-61 332 352 390 .9752
    Lincoln 53-57 .9122
    Lincoln 58-61 .975
    Mercury follows ford pattern.
    Olds 53-61 .9805
    Ply 277 318 .9842
    Ply 361 383 350 1.0936
    Pontiac 55-61 V-8 .9805
    Stude V-8 .8743
  6. RichFox
    RichFox
    Big block Chevys and Lotus 907 engines have .990 wrist pins. My Packard had .9804 pins but I honed the rods to .990 to use common BBC parts.
  7. 1934coupe
    1934coupe
    It would be extremely difficult to ID pistons by wrist pin size. There are other factors least of all WP. size, Bore is the most obvious but a measurement called compression height or distance. Simply said its where the wrist pin is in relation to the top of the piston (not the top of the dome, if any). For example a Chevy 327 and 350 both have the same WP.size and bore size (4") but if you put a 327 piston in a 350 and turn the crank over you will find the piston will come out the top of the block by about an 1/8". If you had the heads on the engine would turn until a piston hit the head.
    Find a TRW or Speed Pro or any piston catalog and check out the different dimensions.
    Good Luck
  8. Little Wing
    Little Wing
    from Northeast
    Great list s thanks guys
  9. dumprat
    dumprat
    from b.c.
    I have an engine rebuilders book no wrist pins. Lists everything from cat to crosley. What size do you have? Might be in the book.
  10. PackardV8
    PackardV8
    Several which have the same diameter will have different lengths and wall thickness. Got to have all three dimensions to confirm what it was for.
    jack vines
