Technical "Wrong" Tachometer
Discussion in 'The Hokey Ass Message Board' started by GraeffSS, Jun 27, 2022.
  1. GraeffSS
    GraeffSS
    Hello everyone, i have a small "project" in mind that I'd like some tech advice on, to see if my logic is right:
    I have a nonfunctional Tachometer i planned to use on my truck, everything else, housing, bezel, gl***, is perfect. The plan was to replace the internals, and i can find some NOS ones that fit the housing for reasonable prices, the catch: they're for a 4 banger and I'm running a 6
    Now, If I understand things correctly, it should work, but read 50% more (for example, at 2000 RPM it reads 3000). Since i plan to make a new face for it to match my other gauges, it would be simple enough to compensate for it. The tach reads all the way up to 8000, which "corrected" would be ~5333, so, about the max my stock 261 should ever run.
    Is my logic right, or there's more to it than simply the pulse count of a 4 vs 6 cylinder?
  2. Tim
    Tim
    from KCMO
    Photos would be helpful
  3. PhilA
    PhilA
    Your logic is correct.
    A basic tach is simply a miliammeter. It'll read the average of the current drawn via the points, which is however many pulses per revolution.
    Hook a tach for a 6 cylinder engine to a 4 and yes, it'll just under-read on the original calibrated markings by 50%. (Conversely, hook a 4 cyl tach to an 8 and it'll read 2x the engine speed, for example).
    Phil
    squirrel likes this.
  4. 38Chevy454
    38Chevy454
    I agree your logic is fine, and the tach will just read 50% higher on the original scale. But if you make a new facescale "calibrated" for the 6 cyl it will work and read the actual rpm you need.
  5. oldolds
    oldolds
    A lot of older tach's had a switch on the back of them to switch for different cylinders. I have not bought a new tach in years so I do not know if they still do this
  6. GraeffSS
    GraeffSS
    Thanks everyone, I'll follow through with the plan then.
    Aftermarket tachs still do come with the switch, but they wouldn't work in the housing i have.
    Both the tach i have, and the mechanism i want to replace the old one with, are from OEM applications (4", dash mounted), so no switch there...
  7. Budget36
    Budget36
    I wonder if a place like Williamson could convert it to a 6 cyl tach?
  8. goldmountain
    goldmountain
    Don't ***ume that it doesn't have a switch. My OEM Olds Cutl*** tach has a switch.
    Bob Lowry likes this.
  9. Kerrynzl
    Kerrynzl
    I did the exact opposite on Lotus Cortina race car . I re-printed the face on a 6000 RPM 6cyl Smiths Tacho.
    This read 9000 RPM for my Lotus [whereas the 4 cyl Smiths Tachos available only went to 7000 RPM]
    ffr1222k likes this.
