WTF Is This?
Discussion in 'The Hokey Ass Message Board' started by Alamedasam, Apr 26, 2013.
  1. Alamedasam
    Alamedasam
    Hey tool lovers-I found this in a junker. Any of you know what it is or used for?
  2. millersgarage
    millersgarage
  3. Blue One
    Blue One
    from Alberta
    It looks like snow :D
  4. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
  5. millersgarage
    millersgarage
  6. unkamort
    unkamort
    When you squeeze the handles together what happens with the 2 points up front?
  7. Winkle picker for a Henway.
  8. when you squeeze the handles does the hook spin? like for twisting wire?
  9. Alamedasam
    Alamedasam
    The hook spins around several times each squeze.
  10. i think it is for wrapping rebar in a form.
  11. ALLISON
    ALLISON
    its a genital clamp
  12. or for safety wire
  13. unkamort
    unkamort
    Thought so... the only thing that comes to mind is some sort of loom, or weaving tool. I'm guessin'... never seen anything like that
  14. tinmann
    tinmann
    That's just mean!!!!
  15. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Dont know what its intended purpose is but it would make a good titty twister.
  16. camcb
    camcb
    In a freaking horror movie :)
  17. Possibly for twisting twine. The front looks like it has a scissor action as well, which would cut the twine.
    Farm use, if so.
    Cosmo
  18. trollst
    trollst
    Everybody knows its a hoomerhingie, old guys know it as a thingiebobber, sheesh, you young guys don't know anything.
  19. The37Kid
    The37Kid
    Fence wire tightener. Bob
  20. scott 351 wins
    scott 351 wins
  21. IanS
    IanS
    Not sure how you got one of those over there. Its actually used to tell the age of male kangaroos. You sneak up to the largest roo in the mob, that's what a group of kangaroos is called and gently touch the blade section (warmed of course) on to one side of his scrotum, squeezing the tool together the animal will "flinch" slightly when the point touches and the pressure is right. Ours have measuring markers on the opposite end of the tool, so you see what that reads and that tells you how old the Roo is by the size of his testicle.
    Cheers IanS
  22. hotrod40coupe
    hotrod40coupe
    You are a sick man for even making up that story.
  23. MoparJoel
    MoparJoel
    My guess... Is an old set of safety wire pliers for aeronautical use.:confused:
  24. skidro69
    skidro69
    from Dothan, AL
    I am an aircraft mechanic. I have several hand me down safety wire pliers, that date back to the 50s. It ain't that. They are much more compact. I was thinking rebar tiers because, the tie wires come with a loop on each end. I don' know about the cutter tho.
  25. suede shoe
    suede shoe
    That looks like a universal adapter adjustment tool. Saw one in a JC Whitney catalog.
