Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. john mullen
    john mullen
    Finished up on the tail pipe 20220330_141424.jpg 20220330_141651.jpg 20220331_142143.jpg
  2. john mullen
    john mullen
    I just received a check from an anonymous supporter from Kansas with a donation for fuel.
    In his letter he shared a story of family in Ukraine
    Who have had to leave everything and retreat to safer places. Most of us here in the USA take our freedom and safety from aggressors for granted.
    My heart goes out for those who must flee there homes and everything they know for ther safety
    Please say a prayer for those suffering this tragedy..
  3. john mullen
    john mullen
    The engine bay fire suppression system installed this morning one nozel for the oil pan area, one up top for carb fire and one inside the cab for driver safety should they be needed. Safety is paramount in any form of racing. The SCTA / BNI has one of the best safety programs I have experienced in all my racing career. 20220401_115001.jpg
  4. kevinrevin
    kevinrevin
    from East Texas
    Have you considered using thinner oil, like the NAPCAR guys are running nowadays? 0W30 or less is being run for a few hours with no issues. It has to take less power to pump the thin oil than the thicker stuff.
    Stogy likes this.
  5. john mullen
    john mullen
    Yes I have and used it at Bonneville in 2021 however I did have some bearing issues using it. The Nascar engines use a much smaller crank rod journal
    (Under 2 in. Dia rod journal's) that results in a slower bearing speed.
    I would have to replace my rods and cut the crank to run that light oil safely.
    The 262 Ford steel crank hasa 2.200 rod journals and bearing speed at 6500 RPM
    Is very high and needs a heavier oil
    . I run 15 w 40 and pre heat the engine to operating Temps before a p*** down the salt.
    But I'm sure it would be an advantage but at a great expense to change at this point
  6. john mullen
    john mullen
    20220404_150731.jpg 20220404_160911.jpg 20220404_160925.jpg Dave Russell and I worked on fabricating the cover to close the rest of the bed in0 on Saturday.
    I finished the drivers side today. The doors will allow access to the fuel tank and the battery monitor on the p*** side. I'll post more as it comes together
  7. john mullen
    john mullen
    We the header rap didn't work out very well, the headers near the collector is to tight to get the wrap in and just didn't look or fit well, SO,The header and intake got married to the engine today. Onward and upward 20220405_162017.jpg 20220405_161958.jpg
  8. AmishMike
    AmishMike
    Do not really know these trucks: is that cowl vent stock or did u add that to provide fresh air to the carbs? What type air filter u planning?
    Stogy, tomkelly88 and chryslerfan55 like this.
  9. For those about to rock, we salute you.
    Stogy likes this.
  10. john mullen
    john mullen
    That was the old system that we used to get fresh cooler air to the carbs, however because the ducting was to close to the top of the carbs it was to restrictive. We have something new in the works to fix that problem.
    I'll post that as it comes together
  11. john mullen
    john mullen
  12. john mullen
    john mullen
    Working on the forward bed cover and access doors 20220406_142517.jpg 20220404_160925.jpg
  13. john mullen
    john mullen
    Just 12 days before we leave for the Arkansas mile. Got to get on the ball
    Stogy, D-Russ, razoo lew and 4 others like this.
  14. john mullen
    john mullen
    Fabrication of the forward bed cover is done. Now it's on to paint 20220408_145922.jpg
  15. john mullen
    john mullen
    Today was a really great work day for the truck.
    We couldn't work yesterday doing family gathering. So Dave Russell and Lee Pollard came and we got almost everything ready to go to Arkansas.
    The fresh engine sounds impressive to say the least.
    So responsive, really t******* hard and the carbs idle clean and crisp.
    I'm grateful for having Dave and Lee giving up there Sunday family time to get things done.
    We are ready but for some painting and clean up.
  16. john mullen
    john mullen
    Just finished the tune up this afternoon.
    Re adjusted the valves and set the timing to race specifications. Sure is crisp and responsive.
    Gona be fast enough??
    We will see, I say hell yes
  17. john mullen
    john mullen
    7 days to go for Arkansas
    The Magic Ratchet and Stogy like this.
  18. john mullen
    john mullen
    Just finished the repaint on the front bumper. It had a lot of chips and the salt was starting to rust it 20220413_134946.jpg
  19. john mullen
    john mullen
    My brother Jeff from a nother mother came to the shop and set the toe on the 640 today and gave us fuel money to help us get to Arkansas.
    Thank you Jeff and Beverly for your love and support
    You are most appreciated 20220415_104345.jpg 20220415_104354.jpg 20220415_104358.jpg 20220415_104404.jpg
  20. Hey John, what does that rascal weigh now?
    Stogy likes this.
  21. john mullen
    john mullen
    Not sure but I would guess somewhere around 3800 lbs
    Stogy likes this.
  22. john mullen
    john mullen
    Big shout out to our friend Louis Mangl*** from Anderson SC for the gas card donation.
    Louis has been a supporter for some time and is appreciated greatly.
    Thank you Louis from all of team 640..
  23. john mullen
    john mullen
    I just want to add that there are many who have supported team 640 for the past 5 years. Mear word's can't express our gra***ude but are felt in our hearts.
    We depart for Arkansas in 4 days and are excited as usual to be going.
    We couldn't keep this project going withought everyone's help. We are so proud to represent you all
    Who are on this amazing journey with us.
    Thank you all so much
    Team 640
  24. john mullen
    john mullen
    20220418_144316.jpg 20220418_144539.jpg 20220418_144509.jpg Cleaned, polished up and ready to go
  25. john mullen
    john mullen
    Sadly I will miss my head wrench This weekend.
    Sam and his wife Tammy will be laying her father to rest.
    Our prayers will be with them and there Family's
    The Magic Ratchet, Stogy and D-Russ like this.
  26. john mullen
    john mullen
    Painted and installed. Just need to paint the blue.
    No time now but will do it when we return from Arkansas 20220418_151648.jpg 20220418_151655.jpg
  27. brett4christ
    brett4christ
    If they gave speed records on effort alone, John, Dave and the team would be a shoe-in!!!
    Good luck guys! Sure hate I can't hitch a ride west to witness the runs! Be safe and have fun!
    saltflats, D-Russ, Stogy and 2 others like this.
  28. john mullen
    john mullen
    Brett,
    Be here Wednesday by 6:00 and come along. Coming back Saturday night, be home in time to rest for work monday.. I have 1 open seat...
    chryslerfan55, D-Russ and Just Gary like this.
  29. brett4christ
    brett4christ
    Don't tempt me!!!! Unfortunately, my calendar is full...and not by my choosing!!! Give'm heck!!
    Stogy likes this.
  30. Stogy
    Stogy
    Looks like its broke the record standing still...Wonderful job Team 640 and thoughts your way for the Checkered Flag of Victory...Safe Travels...;)
