Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. Marty Strode
    Marty Strode
    Happy Thanksgiving, good luck in your racing, with the dedicated crew you have, great memories will be made from working with your friends.
  2. john mullen
    john mullen
    Having trouble finding 302 GMC cranks withought cracks near the rear rod journal. 723328328.jpg 723328343.jpg 723328360.jpg 723328426.jpg 723328664.jpg
    Dyno Dave, chryslerfan55 and Stogy like this.
  3. john mullen
    john mullen
    This is the second one we found like this.
    Dyno Dave and Stogy like this.
  4. Stogy
    Stogy
    You spotted that at a good time...I suspect that's not repairable...maybe I'm wrong. Were they both in the same place?
  5. john mullen
    john mullen
    Yes they were on the last journal before the flywheel flange
  6. ronnieroadster
    ronnieroadster
    Time to step up and get a billet crank shaft its an important block saving part. Contact Henry Velasco also know as Hank the crank Henry will build you a crankshaft that will last you a life time. His turn around time is usually two months. Henrys crankshafts are the only ones we use in our record setting 200 MPH vintage engine's that we run at Bonneville.
    Ronnieroadster
    Dyno Dave, Stogy, ottoman and 7 others like this.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That is the throw that has to carry the torque of all six cylinders firing, on theway to the flywheel. Other throws are not loaded as greatly.
    Dyno Dave, chryslerfan55 and D-Russ like this.
  8. D-Russ
    D-Russ
    Here's the other one. The cracks in both cranks were found when I was starting to polish them. This one is also on the flywheel end.
  9. D-Russ
    D-Russ
    Is it Henry Velasco or Henry Bechtloff? My research says that Henry "Hank the Crank" Bechtloff p***ed away in 2016. Is this the guy you're referring to? Is the crankshaft company still in business? Do you have contact info?
    I also found this for Velasco Crankshaft Service:
    https://www.yelp.com/biz/velasco-crankshaft-service-downey
    Dyno Dave, Stogy and chryslerfan55 like this.
  10. jimmy six
    jimmy six
    I’m guessing one or both may have been the ones I gave you which I knew nothing about. Maybe I’ve been lucky but I’ve never had or seen a cracked one.
    I had a rod bolt break once and destroyed the 3th main web and the crank grinder I used at the time said it was one of the best cranks I’d ever brought him to inspect to use again and I was expecting it to be junk. I still use it today 30 years later.
    Joe Fontana and I ran the same crankshaft in his 12 port for 7 years never using less than 70% nitro and never hurt it. GMC’s have nodular iron crankshafts for strength and I’m sure governed at 3200 did keep them safe. JD
  11. ronnieroadster
    ronnieroadster
  12. john mullen
    john mullen
    Just the last one was one you gave us. The other we purchased from Oklahoma, and it was supposed to have been Magnafluxed according to the seller.
    Not to Happy about that one. Trying to get a refund as we speak
  13. john mullen
    john mullen
    We got on to the bore job for the 302 GMC and got 5 of the 6 holes done. It took 5 cuts to get it to 4.125 from the 4.000 stock bore.
    Hone with a deck plate next 20231208_100910_03.jpg 20231208_105801.jpg 20231208_105852.jpg
  14. D-Russ
    D-Russ
    We made a cover for the quick change today.
  15. saltflats
    saltflats
    from Missouri
  16. john mullen
    john mullen
    Team 640 would like to wish everyone of our friends, supporters, and all who follow our amazing Journey a very merry Christmas and a happy new year.
    Thank you each and every one and remember the real reason for the season..
    May God bless us all in the coming year.
    Just Gary, Stogy, saltflats and 6 others like this.
  17. The Magic Ratchet
    The Magic Ratchet
    ...and the same to you. Merry Christmas! Happy New Year!
    Stogy and loudbang like this.
  18. john mullen
    john mullen
    Installed the QC cover in the truck bed today and did some deburing on the 302 GMC. Dave purchased a set of Steel 4 bolt main caps and I am waiting for some tooling to fit them on the block. Also finally found Lucus 7.5 rear gear oil ( low friction ) and filled the rear case to the proper level. 20231226_125241.jpg
  19. D-Russ
    D-Russ
  20. john mullen
    john mullen
    Setting up the Steel 4 bolt main caps today. I need to fabricate a jig to drill the extra holes for the caps love the ARP bolts and nuts. 20231231_101159.jpg 20231231_101210.jpg
  21. jimmy six
    jimmy six
    Which rear main cap are you using?
  22. john mullen
    john mullen
    I'm using the one you sent me, I'll send the other one that was with the engine back to you.
    jimmy six likes this.
  23. john mullen
    john mullen
    Lee Rick and Scott bleeding the brakes, Dave was in the cab pumping the pedal. 20240106_113929.jpg 20240106_113916.jpg 20240106_113855.jpg
  24. john mullen
    john mullen
    Hanging out with these guys gives me great pleasure. They are by far the best bunch of guys I have had the pleasure to be around. I love these guys.
  25. dart4forte
    dart4forte
    from Mesa, AZ
    This reminds me of a Dodge truck a buddy of mine ran at Bonneville years ago. Not sure the exact cl*** other than PP. He ran a destroked 273, 229ci, and a camshaft ground on a HiPo 289 spec. Had pistons specially made. There were two trucks in his cl***, his and an early Ford PU. He took the record one year but missed attending the following year. A GMC PU from SoCal took it the following year.
    chryslerfan55, D-Russ and Stogy like this.
  26. john mullen
    john mullen
    Work day, loaded the truck to go test in a couple weeks.
    Also fixing some lighting in the shop 20240210_114350.jpg 20240210_114217.jpg 20240210_100234.jpg 20240210_100228.jpg
  27. pprather
    pprather
    Where is the test facility?
  28. D-Russ
    D-Russ
    Either the Dinwiddie Municipal Airport or Virginia Motorsports Park.
    chryslerfan55 and pprather like this.
  29. john mullen
    john mullen
    IMG_6746.jpg Sorry I haven't posted much lately, life sometimes gets in the way. Looking for better days ahead. Stand by for updated to come
  30. rpm56
    rpm56
    I just love the rear end fixture, which appears home made. I'm gonna steal your design.
    Dyno Dave likes this.
