Technical Y Block Adapter Plates
Discussion in 'The Hokey Ass Message Board' started by Humboldt Cat, Oct 9, 2016.
  1. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    Looking for sources for Y Block Adapters to other transmissions. Thanks for any direction.
  2. ididntdoit1960
    ididntdoit1960
    from Western MA
    stick try mummerts auto try bendtsons
  3. Hollow Head
    Hollow Head
    from Finland
  4. Mr48chev
  5. Blue One
    Blue One
    from Alberta
  6. d2_willys
    d2_willys
    from Kansas
    If you are looking to adapt an automatic, then just go with an MX or FMX automatic that will fit right up to the 272/292/312. It has removable bell housing, so you can get the bell off a Furdomatic if need be.
  7. jimmy six
    jimmy six
    I would research which automatic you want then who sells the best adapter kit for that application. Not all of them are equal. There is pros and cons to each. My preferred od auto trans is a 200r (brand be damned) and one of the listed companies make the best one. Good luck
