Hot Rods ? Y-block C2C space motormount bolts
Discussion in 'The Hokey Ass Message Board' started by dana barlow, Feb 25, 2013.
  1. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    ?What is center to center size of two bolt mounts were they bolt to frame?;I've got one bolt Y mounts that I'm using right now,but this is a hotrod and would like to also drill the mount plates for two bolts to frame just in case I ever need to replace them. 2bolt are more EZ to find in a pinch . Thanks if anyone knows the spacing on frame side/not block side. :confused::cool:
  2. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Found out,=2,5/8in. c2c,one bolt dead center. if anyone also needs to know.
