Projects Y BLOCK DYNO DAY
Discussion in 'Traditional Hot Rods' started by Mummert, Aug 12, 2014.
  1. Mummert
    Mummert
    I have them in stock right now. Heres the deal. The pushrod clearance with 1.6 rockers is very close. The 1.7 's wouldn't work in the traditional format. The shaft had to be moved closer to the intake manifold. Our aluminum heads had the rockerarm bolts moved around to allow this to happen. If you have iron heads you would need a special set of rocker stands and would probably have to notch the shafts to get the bolts to clear. They basically built for our heads. I wouldnt say they can't work on iron heads but would take a little tinkering.
    dana barlow likes this.
  2. metal man
    metal man
    I was wondering how you achieved so much lift. Thanks for the explanation .
    I'd like to know a little more about the crankshaft ...it must be a 292 crank since it's a truck crank, right? What years of trucks had that steel crank? My 292 that we will be building soon is a '62 truck engine.
    I was considering using a 312 crank,is this a better way to go?
  3. 69fury
    69fury
    from Topeka
    Good lord- I never expected anything looking like that- and you got some stout numbers off it. That's bad ***!-rick
  4. Babar40
    Babar40
    from Florida
    Wow! Great job on that monster!
  5. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Out ****ing Standing!!!!!!!!!!!!!!!!!!!
  6. brechlrl
    brechlrl
    from Wisconsin
    Congrats John and Geoff.. I think your 1.6 hp/cu in puts you at the top of the heap of Y Block builds Now you need to do one of those 375 inchers and get 600 hp
  7. Tedd
    Tedd
    John. Those are some terrific numbers. Keep up the great work. Ted.
  8. Mummert
    Mummert
    Thanks for the nice comments guys.
    A couple of things I hadn't mentioned yet. The timing cover on this motor is new new! Its a shortened version of the original. It takes 7/8" off the front of the motor for some of those tighter fitting custom applications. Ted Eaton supplied us with one of his electric water pumps. The combination of the 2 peices really cleans up the front of this engine.
    This engine ran well, not quite as powerful as the 343 with the dual plane but more powerful than the 343 with the single plain on "this" dyno. 8 o2 sensors is one of my new favorite things.
    There are some new parts in the works and on the drawing board right now..
    I think the next couple of years are gonna exciting for Y BLOCK.
    .Turtle. and dana barlow like this.
  9. toucan
    toucan
    from sc
    love me a yblock,really love me a bad *** yblock!
  10. OldColt
    OldColt
    Actually, making 1.6 hp/cu.in. at 7000rpm, puts this Y-Block near the top of the heap of ANY small block single 4bbl 2 valve per cylinder engine. Very, Very impressive !!
    --- Steve ---
    loudbang and dana barlow like this.
  11. Mummert
    Mummert
    The engine was originaly setup to be a 7500-8000 rpm deal. But seeing how it will be bracket raced and get a fair amount of useage we backed down on the camshaft at the last minute to drop the rev range. There is definitley more power in it especially with some q16 and camshaft.
  12. could you tell us what crankshaft damper you used? Almost looks like SBC, which might work with the shorter timing cover?
  13. ohv4d
    ohv4d
    castcrankLR.jpg The crankshaft damper is an ATI SBC. It had to be honed a few thou and re-keyed. The new timing cover has the marine pan rail and takes a Y-Block water pump. The damper was extended so the pulley would line-up with a std water pump.
  14. Groucho
    Groucho
    STOUT! Good job
  15. JoeyP.
    JoeyP.
    Way to go , that's pretty serious. I have a soft spot for these engines
  16. terry k
    terry k
    from toledo oh
    Have you tried any dual quads or tunnel ram type fuel systems ??
  17. bchctybob
    bchctybob
    Man, the more information that you trickle out the more exciting the story gets for us oddball engine lovers. My ol' buddy Mike VV is doing similar things with his Studie motors. Way cool stuff!
  18. Pretty big numbers on a Y block! I think that'll push my little Roadster down the track pretty quick.
    Posted using Full box of Crayons on the Kitchen Walls App!
  19. Very nice! Good job as always John!
  20. Mummert
    Mummert
    We have been working on a new intake manifold that will be a tunnel ram or EFI compatible
    with different tops. Ted Eaton done some dyno pulls on a prototype of the tunnel ram.
    It has shown some promise and is being refined.
  21. terry k
    terry k
    from toledo oh
    You are making me rethink using a big FE motor in my T-Bird g***er build.......
  22. Mummert
    Mummert
    Your're supposed to be thinking about putting the Y Block in it:)!!
  23. rodl
    rodl
    Hey John,nice work on the motor. I guess having buddies like Tim and Ted helps enormously:) Looking forward to seeing//hearing about its performance in a rail!
  24. dana barlow
    dana barlow
    from Miami Fla.
    Y-block has been in my old hotrod from the time I built the rod in 1959,still driving. John's HP is exzelerating info,. I have been working along slowly on a homemade 4x2 log intake to dress it up some extra. Now that I completed the restore .
  25. terry k
    terry k
    from toledo oh
    That IS what I meant !!! I was planning on installing the big block in place of building the Y-Block. I am using a Y-Block in my '32, but was not finding enough HP with the 292 until I saw your latest numbers. Keep it up..... Great progress...
  26. Mummert
    Mummert
    Yeah the y- block builders and parts manufacturers are few and far between. Everyone involved pulls their weight to keep these old war horses moving forward. Luckily were dealing with an engine that is scratching on the racing scene again so everyone doesn't have to feel like were launching rockets. It makes it easier for us to work together.
  27. Mummert
    Mummert
    Terry a well built Y block will get it done for you.
  28. 65COMET
    65COMET
    Mummert;that is a serious piece,AWESOME!!! How is the Falcon coming along? ROY.
  29. ohv4d
    ohv4d
    The 64 Falcon is in the paint booth today and the Y-Block is here ready and waiting. It will still be a few weeks before it gets to the track but our local track stays open until December. Should be able to sort things out by then.
  30. glrbird
    glrbird
    Who came up with the design of the fabed manifold? That would not been my first choice, but numbers like that don't lie. Great Job.
