Technical Y block exhaust manifold question
Discussion in 'Traditional Hot Rods' started by zanelpe, Feb 23, 2018.
  1. zanelpe
    zanelpe
    Fellas: I have a pair of stock, cast manifolds, part numbers, ECV9430A and ECV9431A. They appear to be for dual exhaust but I cannot figure out what vehicle they are for. Can anyone point me in the right direction, thanks much, Pete
  2. squirrel
    Lincoln 368, 56-57 continental
    dana barlow likes this.
  3. zanelpe
    zanelpe
    Jim: That was fast, thanks much.
    So I guess that I cannot use them on a 292 / 312 y block, oh well.
    Thanks again, Pete
  4. squirrel
    I got that from google, the only result was a book that showed the casting numbers. you should be able to find it if you also google the casting number.
    On a positive note, those cars are worth a fortune, so maybe the manifolds are worth five or ten bucks.
  5. Alaska Jim
    Alaska Jim
    They will not fit a 272, 292. or a 312., if they are for the Lincoln.
  6. town sedan
    town sedan
    For a car? Look for 1957 & up Ford dual exhaust manifolds. These later manifolds will be flatter on the top compared to the round top early dual manifolds. The later manifolds flow a little better and can be found even on single exhaust cars through 1962.
    -Dave
  7. blucar
    blucar
    If you are looking for stock Ford dual exhaust manifolds for a Y-Block I have a pair for a 55-56 Ford. If you are interested I'll dig them out and check the casting numbers..
