Technical Y Block for my 49 Mercury
Discussion in 'Traditional Customs' started by Bill Blakeley, Oct 13, 2015.
  1. Bill Blakeley
    Bill Blakeley
    Thanks, yeah I would love to see if it would turn over, if so, clean the carb, and see if she will fire
  2. Bill Blakeley
    Bill Blakeley
    That's what I was worried about, was if the oil pan would clear. Had the same problem in my 62 Chrysler 300 custom project, it has an aftermarket front clip, so I went with the Dodge truck pan on the 440, problem solved.
  3. Bill Blakeley
    Bill Blakeley
    I make okay money, been doing it for 35 years, took a while to get there, but yeah, I could use more money for sure.
  4. Bill Blakeley
    Bill Blakeley
    Right on
  5. desotot
    desotot
    The bottom half of a gm engine is sort of the same shape as a flatty which is why they fit with out too much h***le. Front sump pans are a h***le.
  6. japchris
    japchris
    from England
    I've put a Y-Block in my 50 Merc project. Its a bit of a snug fit. I had to alter the front cross-member to get the engine in without it sitting at a jaunty angle. I made some unboltable side mounts. Also modified the front engine steady. Notice the dropped steering arm done by a previous owner. I'll re-do that with less of a drop, but it still needs a bit to ensure it clears the sump safely. Stock manifolds help clear everything. Fitting dynamo in stockish location is a squeeze.
    I found this link invaluable in knowing what I was getting in to! -
    http://www.jalopyjournal.com/forum/...engine-transmission-mount-fabrication.383227/
    Bill Blakeley and desotot like this.
  7. desotot
    desotot
    japchris, I have to say that yblock with 6 94s and mercury valve covers looks great!
  8. Bill Blakeley
    Bill Blakeley
    Looks great
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Or you get a 302 and AOD and fake it like this guy (he sells the valve cover adapters) and have folks scratching their heads. fake y-block.jpeg
  10. JeffB2
    JeffB2
    from Phoenix,AZ
    Here's another in disguise :
  11. Bill Blakeley
    Bill Blakeley
    Lots of great information guys, wow, sounds like a chore. Well since I am a Mopar guy, what are the odds of sticking a big block 383 Mopar engine in the hole? I already have that engine, came out of my 62 Chrysler 300 custom project, I am sticking a 440 in that car. I mean if I'm going to have to do a bunch of modifying anyway, might as well stick something in there with some beef. The 62 383 was rated at 305HP with a two barrel carb, I can get a 3 dueces set up for that engine, and make it look nostalgic.
  12. Bill Blakeley
    Bill Blakeley
    My 62 Chrysler 300 custom project
    Bondo Slinger likes this.
  13. Bill Blakeley
    Bill Blakeley
    This car will have a 440 with dual inline carbs, I'm only about half way done with it, so the Mercury is a back burner project, but I will be working on it too.
  14. Bill Blakeley
    Bill Blakeley
    The Mercury is going to need floor work anyway, so if I mock it up with the 383 engine and perhaps a 6 speed transmission, I can build the floor and firewall around it. I was told to find a rear end out of a mid 90s Ford Expedition, to get disc brakes and a sold foundation, has anyone done this? Is it a bolt in, or does it need modified?
