Technical Y block fuel pump
Discussion in 'The Hokey Ass Message Board' started by AldeanFan, Oct 26, 2018.
  1. AldeanFan
    AldeanFan
    What’s the best fuel pump for a y block?
    I have an airtex pump from rock auto and it’s putting out 10lbs of pressure and I’m chasing fuel leaks.
    Truck64 likes this.
  2. jimmy six
    jimmy six
    Geez mine puts out 4. If you want to keep it add a regulator. Our race cars puts out 10+ regulated to 5.5 max.
    dana barlow likes this.
  3. A_Burly_Wind
    A_Burly_Wind
    I did the airtex on mine and its nowhere near that high
  4. Truck64
    Truck64
    from Ioway
  5. AldeanFan
    AldeanFan
    Definitely a piss off.
    Drove the car to fill it up with gas before I park it for the winter and find this.
    Do I buy a new pump and risk the same problem or add a regulator I shouldn’t need?
  6. miker98038
    miker98038
    If you decide on a regulator, get a good one, not one,of those cheap ones with the dial on top. They leak or fail in short order. I’m partial to Areomotive, but there’s others. If you’re running a stock carb on a y block the required pressures are pretty low.
  7. Truck64
    Truck64
    from Ioway
    I bought the one in the pic. Spec in manual is 3.5 - 5.5 psi. It measures 5.5 psi. They have one left.
    I have pretty much swore off any new manufacture parts if at all possible. NOS or NORS are made to better tolerances, they fit better, and made with better materials.
    Modern parts are less expensive but throwing away the ****ty parts and having to buy them over again plus the labor involved and aggravation you won't have saved any money.
  8. Bleach
    Bleach
    How long ago did you buy it? Send it back and get your money back if wasn't that long ago. Check their return policy.
  9. AldeanFan
    AldeanFan
    I’ll probably buy this pump and keep the one I have now for my emergency road trip parts box
    Thanks
    Truck64 likes this.
  10. AldeanFan
    AldeanFan
    It’s almost a year so probably can’t return
  11. 302GMC
    302GMC
    from Idaho
    I still have the record …. Airtex on a Cheevie V8 that produced 18 1/2 lbs ….
    Truck64 likes this.
  12. FityFive
    FityFive
    I recommend a Carter M3528 fuel pump as it puts out 4 1/2 to 5 1/2 psi. This fuel pump is used on Y block and FE engines.
    Summit carries this pump but states the psi rating incorrectly at 10 psi. I called Carter to double-check and they confirmed 4 1/2 to 5 1/2 psi.
    Truck64 likes this.
  13. Bleach
    Bleach
    I wonder if shortening the fuel pump diaphragm rod or putting in a weaker spring would lower the output pressure.
    Truck64 likes this.
  14. Truck64
    Truck64
    from Ioway
    Yes, but the cheaper pumps (like that Airtex) aren't put together with screws, they are crimped. Rebuild kits for the Carter I posted above are something like $10, if ever needed.
    Bleach likes this.
  15. Truck64
    Truck64
    from Ioway
    Geez.. Did you ah, discover that the hard way, or test first? Lol
  16. 302GMC
    302GMC
    from Idaho
    Q-Jet … they like a lot less ...
    Truck64 likes this.
  17. Bleach
    Bleach
    I guess I haven't seen a non-rebuildable fuel pump for a Y-block. I have 3 of them, including the one on my car and they're all rebuildable OEM's. I'm holding on to all of them.
    Truck64 likes this.
  18. AldeanFan
    AldeanFan
    Thanks for all the great advice.
    I ordered the carter pump, $50 Canadian delivered. It should be here next week.
    I couldn’t find a NOS pump that would ship to Canada.
    I’ll also dig through my leftover parts boxes in the attic and see if I have the pump that came on the engine and if I can rebuild it.
    Truck64 likes this.
  19. FityFive
    FityFive
    Would you be willing to give us an update once you get the new pump installed?
    Truck64 likes this.
  20. AldeanFan
    AldeanFan
    Will do, hopefully I get another good drive in before winter storage
  21. AldeanFan
    AldeanFan
    Follow up
    Results inconclusive.
    I replaced the airtex pump with the new Carter pump and it leaked much worse than before, but this time from the gauge.
    I took the gauge off and replaced it with a pipe plug.
    Now the car is running great with no leaks but the gauge is sitting on my bench reading 4psi.
    I’m blaming ethanol gas and Chinese manufacturing.
    Truck64 likes this.
  22. FityFive
    FityFive
    Thanks for the update.
  23. Richard Zuburg
    Richard Zuburg
    I found 3 y-block fuel pumps available. I may need one for a 292 installed in a 1956 T-bird. Which of these are the best?
    Airtex
    Carter
    US Motor Works
  24. lippy
    lippy
    from Ks
    So the gauge was junk? Or the fittings and line? Lippy
  25. egads
    egads
    It's a ****shoot, but I would try the Carter.
  26. AldeanFan
    AldeanFan
    I recommend the carter.
    I’ve had the carter on my car for two summers now and no problems.
    The airtex put out too much pressure and causes leaks.
  27. AldeanFan
    AldeanFan
    The airtex pump definitely put out too much pressure, then the gauge started leaking.
    I’m ***uming the high pressure pump ruined the gauge.
