Technical Y block generator into flathead
Discussion in 'Traditional Hot Rods' started by g bagwell, Mar 24, 2016.
  1. g bagwell
    g bagwell
    from ct usa
    Can you use a y block 12 volt generator in an 8ba if you cut off the mounting ears, and drill a hole in the case for the pin in the flathead stand?
  2. alchemy
    alchemy
  3. g bagwell
    g bagwell
    from ct usa
  4. lodaddyo
    lodaddyo
    Yep you can do it. I just did it with mine. I also fitted a pulley with a fan mount from a '38 flathead to get me more clearance fitting my 8ba in a 31 roadster
  5. g bagwell
    g bagwell
    from ct usa
    Cool thanks for the info. I have a 53 merc flatty in my 36 with an 12 volt pusher fan. I don't want to spend $300 on one of those power gen speedway jap units.
  6. g bagwell
    g bagwell
    from ct usa
    I may play hell finding a 5/8 pulley for it though.
  7. alchemy
    alchemy
    Thought you had a 8BA? Just use the pulley that came with the 6-volter.
  8. g bagwell
    g bagwell
    from ct usa
    Same size shaft and taper?
  9. alchemy
    alchemy
    The 8BA 6-volt generator has the same armature dimensions as the later 12-volt armature. The pulley and fan should swap right over. No taper on a post-48 generator, it uses a woodruff key to keep it in place.
    If you need a pre-'48-style pulley you will need to find either a very rare piece (I've only stumbled on one at a swap meet in the last four decades) or machine an early out to the dimensions of the bigger armature. I needed a pulley with a fan mount on the front for my '32 Ford application, so I did the machine-work option. After it cracked because the casting wasn't thick enough, I installed the very rare pulley from my stash. Mine came from a larger size generator probably installed on a truck that needed more juice than a regular truck (firetruck?).
  10. sidevalve8ba
    sidevalve8ba
    I've got a y-block generator on my 8BA that is in my '32. All I did was use a wide pulley from a 6-volt generator.
  11. alchemy
    alchemy
    A wide pulley from an 8ba would be a pickup or a 49 Merc part, right?
  12. sidevalve8ba
    sidevalve8ba
    Yes.
  13. dan c
    dan c
    i ran a flathead ('49) pulley on a ford alternator
