Technical Y-block ignition issues
Discussion in 'The Hokey Ass Message Board' started by NAES, Jun 29, 2018.
  1. NAES
    NAES
    Hey everyone. I was helping a buddy of mine on his '57 Fairlane today and we ran into a few issues I'm hoping you all can help with.
    Car has a 292 in it and the original distributor took a dump on him. He bought a knock off HEI billet distributor with coil and wires. Hooked it all up and no spark. 12v to the coil, 12v to the leads in the distributor. Coil shows about 6000ohms. 10v(ish) when cranking the engine. There was a ceramic resistor for the negative lead on the original coil which we byp***ed thinking the voltage was getting reduced (insulated in spite of what the pic suggests). We're stumped. The only thing I can think is other than a faulty pickup on the distributor is that the coil isn't HEI rated. Its not marked in any way so I don't know how to test it. Here's a few pics of where we're at.
    20180629_124159.jpeg 20180629_124204.jpeg 20180629_124217.jpeg 20180629_133342.jpeg
    Sent from my SM-N910V using The H.A.M.B. mobile app
  2. sevenhills1952
    sevenhills1952
    Hold the phone! Or I'm missing something.
    1) stock distributor "took a dump"...couldn't it be fixed, points & condenser?
    2) you show HEI distributor and points coil...instructions clearly state must use HEI coil!?!?!
    Sent from my SM-S320VL using Tapatalk
  3. AldeanFan
    AldeanFan
    Why not use a rebuilt distributor?
    I got mine from rock auto
  4. Truck64
    Truck64
    from Ioway
    I agree. BUT, "Caveat Emptor".
    Y Block distributor cores have apparently dried up (again.) I don't know exactly what the rebuilders are using as cores these days for their rebuilds but, they won't work, the dimensions from the gear to the mounting flange are way off. Big discussion over at Y-blocksforever.com a while back.
  5. manyolcars
    manyolcars
    and dont buy the chinese y-block distributor
    Truck64 and egads like this.
  6. sunbeam
    sunbeam
    Looking at the picture ground or bolt the coil down
  7. manyolcars
    manyolcars
    Coils rarely go bad but the Pertronix coil on my 292 quit working. It was only 16 years old...Git yer y-block distributor out of the trash can and fix it. Problem solved
    Bleach and dana barlow like this.
  8. NAES
    NAES
    Thanks everyone for the replies. I thought the same thing about the coil but my buddy said it was advertised to work on both FWIW.
    The stock distributor is on a shelf. When you hold the rotor and gear in each hand and rotate it, it just moves position and stays there. I'm ***uming the advance return springs or weights are the issue but we didn't delve into it at all.
    I'll have him go back and find the info for the coil and see if he can get specs for it.
    Thanks as usual everyone, NAES
  9. Bleach
    Bleach
    I think the HEI coil will solve the problem. Screen Shot 2018-06-30 at 2.57.50 PM.png
  10. sevenhills1952
    sevenhills1952
    I would take it apart and soak it in carb cleaner or wash tank...see what's wrong.
    Bleach likes this.
