Hot Rods Y Block in a 35-40 ford?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Oct 7, 2010.
  1. Roothawg
    Roothawg
    I have been reading through a pile of old hot rod mags trying to see if I can find a Y block in a 35-40 Ford. I see a ton of them in model A's, but the firewall has been moved back.
    I have been toying with the idea of putting one back in my 36 pickup, but I really don't want to cut the firewall. Any idea if it will fit? I am almost positive it will.
    I bought a 292 the other day for a hundred bucks but I haven't gotten around to mocking it up.
    Feedback?
  2. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Well I will tell you this if the Y block is even an inch longer then say a 265 Chevy V8 then you'll be looking at a electric fan or a recessed firewall. There's a reason that they made kits for the early Chevy's and besides the 38-48 Flatheads that's pretty much all that fits in there I think. Even the 8ba flatheads need an electric fan or a recess from what I hear.
    LOU WELLS likes this.
  3. buster6972
    buster6972
    from Florida
    there is a fairly recent rodders journal with a 312 y block placed in a 40 ford. It did look damn nice.
  4. Roothawg
    Roothawg
    I'll have to check it out. Any idea which one? I used to get a sub, but it ran out.
  5. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    40 Fords and '36 Fords are two different animals. the 40's have a bit more room since the radiator doesn't lay back like the 35-36's. If it fits in a '36 it'll go in a 40 but not necessarily the other way around.
  6. Roothawg
    Roothawg
    Bump for the morning crowd.
  7. RAY With
    RAY With
    Where there is a will there is a way and the Y block would look real good. Dare to be different and just say no to GM ****.
    Boneyard51 likes this.
  8. Roothawg
    Roothawg
    I really like the sound of my Y block in the wagon.....thats what got me started thinking about it.
  9. 63Compact
    63Compact
    My Dad had to widen the indent in the firewall for clearance, but his was channeled.
    kidcampbell71 likes this.
  10. Ole don
    Ole don
    I had a 312 in a 47 sedan in high school. I used Hurst front mounts, and had to cut a hole for distributor clearance. The hole was about a foot high, ten inches wide, and came into the inside about two inches.
    jimgoetz likes this.
  11. AAFD
    AAFD
    from US of A
  12. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    This one definitely has a recess....
  13. Roothawg
    Roothawg
    Wow, that is perfect.
  14. Sweet! Looks like an E code motor, I like it a lot! ;)
  15. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    DOn't thy have that external oil pump on them? Is that going to interfere with the steering box?
  16. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I'm really digging that air cleaner ***embly by the way.
  17. The pump fits under the flange for the bell so it is tucked out of the way. If the stearing clears the bell it will clear the pump.
  18. Roothawg
    Roothawg
    It looks like Hot Rod did the swap in July of 56. The only ones on ebay are overpriced, so I guess now I have something to look for at the swap meets.
  19. nobuckets
    nobuckets
    from austin, tx
    I'm working on putting a y-block/t-5 in my '36 and I tracked down the mag already. It's still a good read, but this will give you a head start.
    guthriesmith likes this.
  20. Tight fit, but do-able.
  21. Roothawg
    Roothawg
    Are there more articles other than this one? I can start scanning the swap meets.
  22. cvstl
    cvstl
    from StL MO
  23. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    There's also the trick I heard of using a truck firewall on a coupe to gain some room.
  24. Thirdyfivepickup
    Thirdyfivepickup
    Jim is a good family friend. I know his 36 was built originally in the 50s and used a Hurst front mount. If you have any more questions you'd like to ask him I can get a hold of him for you.
    kidcampbell71 and hotrodtodd1960 like this.
  25. aaggie
    aaggie
    I have been involved with engine swaps since the late '50s and nothing is harder than Ford into Ford. It looks easy then you find that everything needs modifying to get it to fit. Some engines are available with rear sumps to clear spring and crossmembers and some have p***enger side starters to clear steering boxes. Any with rear distributors will not clear the firewall without recessing or cutting out a section.
    When you get it done it is an accomplishment but you now know why there are so many SBCs in old Ford hot rods.
  26. Roothawg
    Roothawg
    Dang Clay, it doesn't get any better than that. I totally forgot about that post. It never came up searching under Y-block stuff.
  27. Roothawg
    Roothawg
    I emailed him. Thanks.
  28. fleetbob50
    fleetbob50
    from Waco,Texas
    The 34 ford pickup i drove in high school had a 312 in it and I didn't have to change out or cut anything...so it should fit later model wider frames with flyin colors
  29. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Only thing is that a '35 Coupe's engine bay is probably shorter then your '34 pickup since the grille shell leans back as far as it does.
  30. Steve 38
    Steve 38
    This beautiful 36 is the subject of an article in American Rodder January 2008 issue.
    Rodders Journal did a story on a 39 Deluxe with a Y Block from a Thunderbird. Looks great with twin Autolite carbs. It was issue 42.
