Technical Y block in a 40 Ford
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Jan 11, 2026.
  1. junkyardjeff
    junkyardjeff
    There is a 40 that has been for sale near me for awhile and thinking about looking at it next weekend if not sold by then,it has a running flathead and would like to keep it if I get it but something tells me its not going to be enough. I have a good 55 272 in the garage and have a truck timing chain cover to use with Hurst style mounts and a truck oil pan so will one fit without major cutting,I put plenty of Y blocks in the 1/25 scale versions but not a real one.
    Torkwrench likes this.
  2. Roothawg
    Roothawg
    I think the firewall may have to be recessed a tad.
    warbird1 likes this.
  3. AVater
    AVater
    ^^ Agree based on my experience with a ‘35. The distributor will bite you.
  4. junkyardjeff
    junkyardjeff
    Actually there are two 40s available,the stock one and another that has a recessed firewall with a MII front suspension. I was hoping a Y block would go in a stock 40 relatively easy as I was wanting one with stock suspension,the stock 40 is all together and the other one has no windows or interior.
  5. Torkwrench
    Torkwrench
    Do you follow Iron Trap Garage on YouTube? They saved a 1939 Ford Deluxe sedan out of a junkyard. It had a Y block swapped in many decades ago.
    There is a whole series of videos on this car. Might give you some ideas. Attached is the short compilation video.
    Junkyard To On The Road In 25 Minutes - 1939 Ford Forgotten Hot Rod
    PONTNAK123, Toms Dogs and Roothawg like this.
  6. Roothawg
    Roothawg
    I love the idea of a Y block in a 35-40 Ford. I keep thinking of putting one in my 36.
  7. AVater
    AVater
    Here’s how I approached it with the goal being have it look like the firewall could have been stock and I could use a stock toe board. Hope this helps.
    pprather, y'sguy, Andamo and 2 others like this.
  8. Roothawg
    Roothawg
    I have heard the starter is the biggest issue.
    @AVater that looks great. Any pics of the firewall in progress?
  9. junkyardjeff
    junkyardjeff
    Are those Hurst style mounts still available.
  10. I sent these to @Okie Pete
    Y to 37-48 ford IMG_0456.jpeg IMG_0455.jpeg Bolts to timing cover and oil pan
    Relocates the gen on top
    guthriesmith and Moriarity like this.
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    No, they haven't been for years. I haven't seen any reproductions.
  12. williebill
    williebill
    Hurst mounts for the Y block ahow up on Ebay sometimes.
  13. enjenjo
    enjenjo
    from swanton oh
    I had a 312 in my 41 Ford pickup back in 1965. Offy adapter to the stock transmission. I don't recall any issue with the distributor hitting the firewall. I did use a truck oil pan and pickup. My dad and I built our own Hurst Style motor mounts.
  14. AVater
    AVater
    Below is an attempt to explain how I recessed the firewall. Keep in mind, I am a negligent photographer as so often I don’t “remember” to take pictures until after the work is done :oops:
    With a goal being to make the final work look like it came from the factory that way, I looked for how much space was needed and natural places to cut. I decided that limiting the recess on the p***enger side to center of the x embossed in the firewall made sense. Likewise, I made the add in piece to match depth of the already present firewall recess. I then took some 18 ga steel for an add in piece and worked to make a factory sized curved bend in it. Luckily I had some old pipes and clamps to make that work and did waste a couple try’s before I got what I wanted. I left some steel on the extension to help attach it to the firewall on the upper and p***enger sides.
    Luckily, I had a ratty spare firewall to practice cutting and fitting. and did so so I could see what would work on the real thing. This was definitely a measure twice cut once situation when it came to the “real” firewall.
    The real firewall was then cut and the patch welded in.
    Sorry I didn’t photo it and hopefully the poor drawing below will help.
    Btw: the starter did not cause a problem. Let’s see what I say about that if I need to change it someday.
    Also, yes a truck oil pan works best.
    Motor mounts are also home built and the engine is offset a bit to the p***enger side.
    I’m using Ford ram horn exhaust manifolds.
    Okie Pete likes this.
