Technical Y block in a 53 F100
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, May 12, 2024.
  1. junkyardjeff
    junkyardjeff
    After getting my 37 Chevy p/u out for the first time this year it seems the cab is shrinking so maybe time to step up to a larger truck,since I have Y blocks I am thinking 53 to 55 F 100 but if I end up with a 53 what will it take to put a Y block in where a flathead was originally. I presume getting 54 and 55 parts but are the frames different.
  2. Think the FH crossmember is the biggest difference
    Stab that Y in there and build whatever it needs.
  3. alchemy
    alchemy
    Probably depends a lot what transmission you want to use. Would you stick with the side bellhousing mounts that the Y block Effie's originally used? If so, the front center mount receiver should be easy to fab.
  4. junkyardjeff
    junkyardjeff
    A local junkyard has a 54 or 55 that has the mounts and bell housing and would most likely use them and does the trucks use the same 3 speed as the car. I have a car T-5 adapter I was hoping to use.
  5. Ford in it’s infinite wisdom had different input lengths for cars and trucks
    bobss396 and Truckdoctor Andy like this.
  6. junkyardjeff
    junkyardjeff
    Might just use a car bell housing since I have one and side mount the Y block with a crossmember for the trans like a car.
    anthony myrick likes this.
  7. deathrowdave
    deathrowdave
    from NKy
    Y is cool ! FE is bad ***
    Deuces and RMR&C like this.
  8. What about a, ah, never mind, those who know me can finish my thought. My thoughts are the same as what would @Lloyd's paint & gl*** do?
    Lloyd's paint & glass likes this.
  9. junkyardjeff
    junkyardjeff
    Hopefully I can find a 54 or 55 so it will all bolt in but then I have a rough 65 Galaxie with a 390 and C-6. I have a sweet running 55 272 and a T-5 that I would like to put in one.
  10. miker98038
    miker98038
    If you go with the engine side mounts, you’ll need the either the truck crossover exhaust, or something of your own design. I know the rams horns won’t clear the side mounts, and I don’t think either a car or tbird left side manifold will get the down pipe by the steering/clutch linkage. The truck guys would know for sure on that. Anthony is right about the depth of the bellhousing, but I think the truck 4 speed used a larger front bearing retainer, while the 3 speed used a smaller one. Just something to figure out when you start gathering parts. Double check the car bell/adaptor/T-5 input shaft length. Some combinations require shortening the input shaft 1/8” or so. Not a big deal, I’ve done it with the transmission on the floor with a cut off wheel and a second set of hands.
    RMR&C likes this.
  11. Dropthat 272/t5 in
    If the junkyard stuff works, use it
    If not, it’s just a little welding
    RMR&C and Truckdoctor Andy like this.
  12. Wanderlust
    Wanderlust
    Just to add the truck 3 sp has a larger bearing retainer and input shaft than the car 3 sp
    RMR&C and anthony myrick like this.
  13. bobss396
    bobss396
    The 352 and 3-speed from my wrecked '64 Ford went into a friend's '53 F100 around 1978.
    IIRC Transdapt had the required front engine cradle. I do not recall any difficulties with the swap.
  14. junkyardjeff
    junkyardjeff
    Does anyone know if the 61 to 64 truck 3 speeds are the same as a car,if so I could use one of those bellhousings as I think they have the mounts on them like the older versions. I picked up a 64 292 for parts a couple years ago that had the front mount but did not have a bellhousing.
  15. Wanderlust
    Wanderlust
    The truck and car 3 speed trans are not same, truck has a considerably larger bearing retainer and input shaft. The truck bells have ears, the car bells that I’ve seen did not.
  16. junkyardjeff
    junkyardjeff
    Probably will need a T-5 adapter for a truck if this happens,I have one for a car.
