Technical Y block in model a
Discussion in 'Traditional Hot Rods' started by 87notch, Feb 1, 2020.
  1. 87notch
    87notch
    from kentucky
    Plan to put my 312 in my 30 coupe and have a firewall question. My coupe is on a boxed original frame and I was wondering if any firewall modification is necessary to clear the y block. I’m not running a hood or fenders so there’s no issues there. I hate to cut up a nice firewall off I don’t have to. I’ve seen them flipped around for clearance and I’m willing to do that. Any help and pics would be appreciated.
    Deuces and dana barlow like this.
  2. I started with a stock '30 frame and stretched it 4 or 5" to get a Y block in, I did not want to cut the firewall. You may be able to get it in with just flipping the firewall. I have a sedan and did not want to give up the rear seats so inside space was something I did not want to give up. it may help to mount the motor low in the frame to gain some room with the bell housing.
  3. warbird1
    warbird1
  4. 87notch
    87notch
    from kentucky
    Deuces likes this.
  5. sunbeam
    sunbeam
  6. Foothillspeedshop
    Foothillspeedshop
    Tim's sedan is on a boling brother model a style frame that has been stretched to fit the y block. If I'm not mistaken the only thing needed to clear the distributor is the flange on the firewall needed to be notched. Boling bro did a stock frame coupe with a y block not that long ago its a blue Patina coupe. they had to make a recessed firewall to clear the back of the engine and distributor.
    Deuces likes this.
  7. micshotrodgarage
    micshotrodgarage
    from colorado
    This is good!! I have a 29 coupe I hope to make it Y-block powered. Have the Offy -3x2 and valve covers, but no engine yet.
  8. Almostdone
    Almostdone
    I would think it would fit with an advertised length of 29 inches, but you’ll have to mock it up to be sure. If you do end up flipping the firewall it’s a fun project and gains a bunch of room.
    John
    -Brent-, sko_ford and 56 ford custom like this.
  9. panhead_pete
    panhead_pete
    Firewalls are cheap, buy another and cut to fit and/or reverse it its a 30/31 like @Almostdone did.
