Has anyone ran a triple deuce setup on a 272 Y-Block? What did you use for carbs and what type of adjustment did you have to make to make it work? A single carb is so boring, what could be an idea to run for carburation? I was thinking a triple deuce setup or a dual Deuce setup (adapter plate on a quad intake) Thanks Fellas!!
You are going to find alot more 3x2 setups than 2x2s, I don't think I've ever seen one. I run an Edelbrock 500 on mine and I have fun with it. My Holley 600 made it run like*****. If you get a 3x2, the Edelbrock intake, I think it is # 557 is the one to get, I know that 553 does not flow as well.
ive got a 3 pot intake running 3 94s... havent had a chance to put it on.... i can take some pics of the linkage if needed
my only concern is over carburating the 272 motor. If I was running a 292, I wouldn't flinch on putting on a 3 deuce setup. I guess i could blank off one of the carbs of the 3 or even down jet them all. thanks.
94's are 155 CFM so I have been told. Three of these (8BA's) would give a total of 465, not too much for a 272. Run them on a progressive set up and you will be using only one most of the time. Jets could probably take care of any bog when you mash it.
