Y block intake manifold
Discussion in 'The Hokey Ass Message Board' started by boscosis, Sep 9, 2008.
  1. boscosis
    boscosis
    I'm wanting to get rid of the 2 barrel and intake. I'd like anything else but the factory 4-barrel unit. What else is out there and where to find it (without spending a fortune of course)?2-2's2-4's1-43-2's, whateverThanks
  2. Greasy71
    Greasy71
    from SoCal
  3. sawzall
    sawzall
    i have one of these for sale..
    mint shape.. NO CARBS. ;-(
  4. teddyp
    teddyp
    i have the 57 ford manifold that takes a reg 4 barrel
  5. Paul2748
    Paul2748
    Lots of 3 x2 set ups around, mostly on ebay and mostly expensive but you can get a bargain if you try.
  6. FoMoCoPower
    FoMoCoPower
    Which Y-Block do you have?
  7. Corn Fed
    Corn Fed
    You should be able find a 3x2 at a swap meet, e-bay, or HAMB classified. But you'll be spending more on the buying and rebuilding the carbs than you will on the manifold. I'd estimate you'd have $1000 in a 3x2 setup vs about $400 in a 4bbl. Of course these prices vary greatly on what carbs you decide upon.
    In a nutshell, don't expect to get a multi-carb setup going for cheap.
  8. 50shoe
    50shoe
    find a 573 Edelbrock if you can. they are supposed to flow the best. or get sawzall's for the simple 'wow' factor. :) of course you need 2 corvette/corvair carbs for it.
