1952-59 Ford y block intake
Discussion in 'Off Topic Hot Rods & Customs' started by dragonknucks, May 27, 2011.
  1. dragonknucks
    dragonknucks
    Can someone tell me what engine this intake came off of? I've never seen one like this one. Therefor I figured it was from a 239. Not exactly sure though. I have the carb that goes with it and the thermostat housing and thermostat. Please help. Any idea what it would be worth? Or should I just put it on the wall? Thanks guys!
  2. streetdreams
    streetdreams
    Early 272 or 292 with the early 3 bolt 2 bbl carb. Worth its weight in s**** iron, or, hang it on the wall for garage art.
  3. Retro Jim
    Retro Jim
    They make great boat anchors too !
    Yes to Y blocks !
    Jim
  4. 1956Ford
    1956Ford
    Would a 2bbl be more gas economical than a 4bbl?
  5. flyboy89
    flyboy89
    from So. Cal.
    It depends. I once had a '70 Chevy Nova (back in the early '70s) It had a 350/ 4 speed and a 2 barrel carb. I switched it to a 4bbl spread bore Holly and got better gas milage. But as they say, your mileage may vary.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    In most cases if you keep your foot out of it,the smaller primaries of the 4 barrell will give you better mileage,you don't need a lot of Carb for your Y-block a 390-500 CFM will do the job.The 600 CFM Holley you have will be OK too with the vacuum secondaries, you won't know till it's on what tuning may be required,what's stopping you from putting it on? You might have to swap to a cable linkage but that's no big deal.
  7. dragonknucks
    dragonknucks
    I think I will just keep it for the hell of it. Thanks streetdreams!
