Y-block manifolds?
Discussion in 'The Hokey Ass Message Board' started by Zodoff, Sep 1, 2003.
  1. Zodoff
    Zodoff
    Does the 56 and up have dual exhaust? My 55 got this two-to-one stuff,I dont want that.. Aint noizy enough!
    What can I use,other than headers? Lots of oilfilter,and steering box there...
  2. k-member
    k-member
    WHO-BAaahhh pipes!
    Viva Garahe!
  3. Zodoff
    Zodoff
    K-mutha! Where ya been? Lost in the world of ink`n needles?
    Ill defintivly go for WHO-BA pipes....
    Why didn`t I think of that?? [​IMG]
  4. Deyomatic
    Deyomatic
    from CT
    My 55 has the manifolds for duals on it. Not sure if it was a stock option or not. Check out ebay, you might be able to find a set or just the p***enger side on there. I am not positive, but I don't think you can use the Ram Horns if you find any, I think the steering box is in the way, or something. Mine just has about a 20" Cherry Bomb on each side and I like the sound.
  5. Deyomatic
    Deyomatic
    from CT
  6. Deyomatic
    Deyomatic
    from CT
  7. carkiller
    carkiller
    54 55 56 take (Use) the rounded style while the 57 up use the squarer type. The 57 up are alittle longer on the flange because of the steering box. If ya dont find any PM me, I stock em. Cal
  8. Edselow
    Edselow
    from TN
    My '59 had a y-pipe connecting the two manifolds, but it was just bolted to the manifolds. Took it off, used the same flanges and made duals with cherry bombs straight back, no problemo. Sounds sweet, just the proper noisage!
    Alan
  9. Zodoff
    Zodoff
    Thanksalot. Im totally fresh on these engines,so this helps alot.. now I know what to look for,to make that sweet yblocksound even better... [​IMG]
  10. Jeff Norwell
    Jeff Norwell
    MODERATOR
    When I had my 55 ford with the Y-block I used Red's headers,reasonable cost and the wonderful smithys.If ya want to make some noise,make sure the rear tailpipe size smaller than 2inch. you will get the pipes to really rap.
    That will bring the Y-block alive.
  11. 286merc
    286merc
    from Pelham, NH
    I come out of 2" Cherry Bombs with reducers to 1 1/2". Then about 3' to turndowns. This is on my 54 F350 with 292 Y Block. Starts off with Reds Headers.
    On the 53 Vicky with flathead I go 1 1/2" all the way back, again with Cherry Bombs up close to Reds Headers.
    On a 68 Impala with 396 Im using 2 1/2" out of the Cherry Bombs but that sound is pure painful at times. It scares the **** out of ricers and SUV's tho when I drop down a gear on the interstates as I blow by them.
    The smaller pipes on the Fords are a lot more mellow.
    BTW, dual exhaust were factory optional on Y's right from the beginning in '54.
  12. Lownwuf
    Lownwuf
    I have a pair of rear dumps off a 55 f-100 if your lookin for a pair.Email me if your interested.
