Technical Y-Block Remote Oil Filter
Discussion in 'Traditional Hot Rods' started by scott Hrncirik, Jul 3, 2023.
  1. scott Hrncirik
    scott Hrncirik
    Fellas -
    I am shoving a 239 Y-Block (1953 F-100 I was told) into my 1932 3 window and need a little more room for the oil filter due to the F100 added steering box. Do the typical kits on Speedway/Amazon (Derale 15715) fit this year Y-Block?
  2. junkyardjeff
    junkyardjeff
    If my memory is correct the big trucks had a angled oil filter ***embly,now it was a canister filter but the spin on adapter might be able to,be used. I never had one apart and only looked at them.
  3. KenC
    KenC
    You'll need a spin-on filter adapter first, then the remote kit should work. But, just going to a spin on may buy you the space you need. Especially if you use a shorter filter than normal. Lots of them are the same at the gasket/thread area.
  4. miker98038
    miker98038
    There have been a lot of leak problems with some of the spin on adapters lately. Here’s a link to a fairly recent discussion over on the barn.
    https://www.fordbarn.com/forum/showthread.php?t=326435&highlight=Oil+filter+adapter
    Odd things sometimes happened with Ford, but the 239/256 y blocks were a 1954 introduction, not 53. If it’s a good running engine, go for it. But if it’s going to need a rebuild do your research first. There’s some noticeable differences between them and the 272/292/312 engines. Parts can be a problem. If you’ve already gone thru it then it you know this by now.
  5. manyolcars
    manyolcars
    did the truck get the y-block a year before the p***enger cars?
    6sally6 likes this.
  6. Mark T
    Mark T
    As junkyardjeff mentioned, Ford used a factory installed angled oil filter adapter. You might be able find one in a junkyard or you can buy one online from Summit or any of the online venders.
    I just read that these adapters can be found on Ford Explorers and an older version was used in Ford vans in the mid 60’s.
    jimmy six likes this.
  7. scott Hrncirik
    scott Hrncirik
    I was looking for something more like this one that will fit the 239 Y-block
  8. miker98038
    miker98038
  9. scott Hrncirik
    scott Hrncirik
    Got it! Thank you guy's for the advice, I appreciate it.
  10. 6sally6
    6sally6
    For the record........pretty sure the 239 came in 54 Fords.
    Jus say'in..........
    6sally6
    manyolcars and Alaska Jim like this.
