Hot Rods Y block rocker arms ????
Discussion in 'The Hokey Ass Message Board' started by junkyardgenius, Aug 6, 2025.
  1. junkyardgenius
    junkyardgenius
    from Kernow
    A friend of mine has a 322 Y block. Just had the heads skimmed and refitted. There's no adjustment on the rocker arms for setting clearances. Are adjustable rockers available or do you have to use adjustable push rods?
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I take it that you're working on a Buick 322, since all Ford Y blocks came with adjustable rocker arms. Adjustable pushrods are probably going to be easier to come up with than adjustable rocker arms for that engine.
  3. BJR
    BJR
    If you are working on a Buick engine, it’s a nailhead not a y block. All y blocks have adjustable rockers. You should change your ***le if a Buick.
  4. Fordors
    Fordors
    There was a Lincoln Y block variant with hydraulic lifters and it was a 332. If the heads just had a mild clean up cut the lifter adjustment might still be OK. The Linc heads also had conventional side by side intake ports.
    seb fontana and Deuces like this.
  5. junkyardgenius
    junkyardgenius
    from Kernow
    Sorry should have said its Ford Y block 312 cu in not 322.
  6. Fordors
    Fordors
    Are you sure about that? I ran with a couple guys that drove Ford Y block powered cars in the late ‘60’s and I recall the ECG-Z heads were the hot ticket BITD. The ECG prefix in the casting designation was for the Ford Y blocks and Ford heads had the over and under intake ports. The ECU prefix was used for Lincoln Y blocks that had side by side intake ports and do not interchange with Ford heads, the engines are similar but not matching. The Lincoln blocks also had a different oiling system that allowed hydraulic lifters, something the Ford Y blocks never had.
    Can you post a photo of the intake manifold showing the port layout?
  7. Flatrod17
    Flatrod17
    All Y blocks had adjustable rockers, as they all had solid lifter cams. There are two rocker ratios as well. I don't remember for sure, but I think it was 1.43 and 1.54 on some of the 312's.
    dana barlow likes this.
  8. miker98038
    miker98038
    In over 50 years of being around ford y block I’ve never seen fixed rockers. They came in 2 ratios (above). They had an adjusting screw with a lock nut and a screw with interference fit threads. I have seen them so slugged up you really couldn’t see the adjustment. Or, it is one of the Lincoln y blocks that had hydraulics.
    This link is to Mummert’s site. Got a fuzzy picture of the ***embly and the various length pushrods for different combinations and milled heads. All the cam cards I’ve seen show lift with the 1.5x rockers.
    http://www.ford-y-block.com/valvetrain.htm
    leon bee likes this.
  9. jimmy six
    jimmy six
    Smith bros in Oregon. 2 day turn around….
  10. HEATHEN
    HEATHEN
    from SIDNEY, NY
    As I understand it, all 1956-57 engines used the 1.54 rockers, and they went back to the 1.43 version in '58.
  11. jaracer
    jaracer
    You sure it isn't a 322 FE?
  12. nosford
    nosford
    You mean 332 FE? Had a couple of those in 59 Wagons with 2 speed automatics (couldn't do the low gear start like my 55 or 57) and they were NOT big on power. Small 2 barrel and non adjustable rockers like most FE engines. I have read that the 59 332 had less compression than the 58 332. I have also read that there was a 4 barrel version available but have not seen one in person. Have seen a couple 352 and 390 police package "interceptor" engines with solid lifters and adjustable rockers.
  13. jaracer
    jaracer
    Yes, it was a 332. My cousin had one in a 59 Ford.
    junkyardgenius likes this.
  14. junkyardgenius
    junkyardgenius
    from Kernow
    Spoke to him earlier its a 332 y block in a 59 Skyliner. Hydraulic lifters. No adjustment on the rockers.
    warbird1 likes this.
  15. jaracer
    jaracer
    Most likely an FE block, not a Y block.
    sidevalve8ba likes this.
  16. Flatrod17
    Flatrod17
    332 is concided in the FE family although it is a y block design. There are adjustable rockers for the FE's, or just have to hunt some down, or buy new.
  17. jaracer
    jaracer
    My cousin had a 59 Ford with a 332 and it was definitely an FE engine.
    From Wiki: The Ford FE engine is a medium block V8 engine produced in multiple displacements over two generations by the Ford Motor Company and used in vehicles sold in the North American market between 1958 and 1976. The FE, derived from 'Ford-Edsel',[1] was introduced just four years after the short-lived Ford Y-block engine, which American cars and trucks were outgrowing. It was designed with room to be significantly expanded, and manufactured both as a top-oiler and side-oiler, and in displacements between 332 cu in (5.4 L) and 428 cu in (7.0 L).
  18. leadsled
    leadsled
    Okay, understand Ford 312.
    You have adjustable rockers and solid lifters. Don't worry about the machine work on the head for valve train. You have adjustable rockers, so set the valve lash with feeler gages. problem solved. What you should be worried about is the intake manifold fit.
  19. junkyardgenius
    junkyardgenius
    from Kernow
    Looks like the info I was given was way off. Got the engine out and after checking the engine number it is a FE from 1961. Now stripped and at the engine shop. It has hydraulic lifters and non adjustable rockers.
    leadsled likes this.
  20. leadsled
    leadsled
    Thanks for letting us know, good luck with the project.
