This will allow you to basically put a Y Block in any Flathead powered Ford/Merc Product. Or with an additional adapter from Speedway put a 5 Speed on a Y Block and slide the whole thing in any car. Hurst Front Mount Generator Tension Arm Bolts and Spacers Correct Pulley Fuel Pump Block Off Y-Block to Early Ford Adapter Flywheel and a Stock Bellhousing with Throw Out fork and T/O Bearing. It's not needed with the conversion but It might as well go with this stuff. I removed this from a 292 Y Block but will fit 272/292/312 $500.00 OBO. Will ship but on your dime. - Tim
