Projects Y block trans adapters
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Jan 2, 2021.
  1. junkyardjeff
    junkyardjeff
    Who all makes adapters to put a newer trans behind a Y block.
  2. 53olds
    53olds
    Flat-O-Matics in Portland,OR
    32Dan likes this.
  3. jimmy six
    jimmy six
    Bendtsen makes one to put a GM 200r behind them...along with other GM transmissions
  4. 51504bat
    51504bat
    hemihotrod66 likes this.
  5. Kiwi 4d
    Kiwi 4d
    What sort of trans are you thinking?
    We put a Y block to flathead adapter on our Y block ,then Flathead to T5 behind that.
    In another of our cars with a Y block we used a wilcap adapter to 700R4.
  6. Mr48chev
    Ford T - behind early (4 bolt) Ford pattern. Ford Narrow pattern and Y-block to Ford Front Shift T-5 Adapter plate - Modern Driveline
    This one adapts a GM manual trans to the Y block Offenhauser 5173 GM Manual Trans to Ford Bellhousing Adapter (speedwaymotors.com)
    The photo and explanation on the adapter to hook the "wide" pattern Ford to the earlier "narrow" pattern bellhousing is a ways down the page. Fun reading for a Y block guy anyhow and I read it in HRM when it came out back years ago. Scroll down the page a ways. Vintage Engines: FoMoCo Y-Blocks- A Close Look (hotrod.com)
  7. glrbird
    glrbird
    FMX auto trans will bolt up to ford-o- matic bell housing Two holes line up, drill the other two. Strong trans
    jimmy six and anthony myrick like this.
  8. junkyardjeff
    junkyardjeff
    I have everything to put a 62 COM with a late 60s FMX valve body behind it but I have a C-4 that is much lighter that I was thinking about going with if I can not find anyone around here that knows how to go through that COM.
    jimmy six likes this.
  9. Corn Fed
    Corn Fed
    20 years ago I put an FMX behind my Yblock. It was not the slam dunk it was supposed to be. I had to have a torque convertor modified so it would fit correctly with the crank/flex plate. I would recommend getting the C4 adapter if you want an automatic. That way you get a lighter, more modern trans and can use the common SBF starter.
  10. junkyardjeff
    junkyardjeff
    What I have for the COM it should bolt it with no modifications,62 trans,flywheel and torque converter but will be looking around soon to see if there is anyone old enough to know how to rebuild them.
  11. 32Dan
    32Dan
    from Chino, CA
    Like 53Olds said, Flat-O-Products makes one that is very nice, cast aluminum. Comes complete with everything you will need to run a C4. Will need to get an FE starter, change the start gear on the nose. Will also need to be mindful of the torque converter bolt pattern, which will be a common one. I used it on my Y Block/C4 drivetrain, no complaints!
  12. junkyardjeff
    junkyardjeff
    I need to call them to see what C-4 to use,I have a pan filled and need to be sure its not for a case filled.
  13. jaracer
    jaracer
    Anyone with a knowledge of automatic transmissions and a service manual should be able to go through a Cruise-O-Matic. It's not hard. The only big difference is that everything come out the back instead the front. However, I'm not sure about the FMX valve body on a COM. It may work, but I haven't heard of it being done.
  14. fabricator john
    fabricator john
    from venice fl.
    about 8-9 years ago i put a 700r in a 55-6 tbird for a fella worked out pretty good i think brendensen( looks like the company usesd is now called speed gems) ? made the kit was very well thought out and complete ..used a trans mount locar shifter came close to the stock spot ..
    >>>>> TEXAS INDUSTRIAL ELECTRIC is HIGHLY RECOMENDED for CUSTOM SPEEDO CABLES ,, they will make anything for anything and know their stuff great service and quality stuff <<< Fabricator john
    miss you dad
  15. Jhook
    Jhook
  16. Jhook
    Jhook
    Just installed a 700R4 in my 1956 Ford 292, used this Wilcap adapter and everything fit perfect and I love the overdrive.
  17. jimmy six
    jimmy six
    One of the C4 adapter is a the bellhousing too and not just a plate.
  18. 55blacktie
    55blacktie
    I have the Flat-O Products kit for mating a C4 transmission to my Y-block. The kit calls for a case-fill C4, not pan-fill. The pan-fill was used in trucks. It has a larger bell housing that does not bolt to the front pump, like the case-fill C4. You can also use a case-fill C5, but you will need a C4 valve body and torque converter, as the C5 uses a lockup converter/w a larger, deeper bell housing. you will also need an FE starter, not an SBF. Most f this information can be found on Flat-O Products' website.
    By the way, Gene does not like email. if you have a specific question, you need to call him.
  19. 55blacktie
    55blacktie
    Gene prefers the later C4 transmissions, not the early Select-o-matics. The later transmissions also have a 26-spline input shaft. I'm using A Hughes 41-20 torque converter. Unlike the OEM C4 torque converter, there is no need to have the studs tig welded, as per Gene's installation instructions.
  20. 55blacktie
    55blacktie
    Early C4s use an 8-bolt valve body. Later C4s use a 9-bolt valve body. A 9-bolt valve body can be used on an 8-bolt transmission by putting a nut & bolt in the extra hole. However, the earlier 8-bolt valve body cannot be used on a later 9-bolt transmission.
  21. Blue One
    Blue One
    from Alberta
    I have a C4 adapted to my Y block with a Flat O kit.
    Their bell housing is really good as is the rest of the kit.
    Don’t bother with trying to adapt a starter as is mentioned in the kit which includes a bendix drive to a Ford starter from a different Ford engine .
    Gene can also sell you a compact high torque starter that bolts right on and has a built in solenoid which makes wiring easy.
    A great kit.
    And yes a case filled C4 is what you need.
    Gene does prefer to be contacted by phone.
