I have a simple question about a Y block Standard transmission used in a CAR: what is the length of the input shaft? Put another way in a car/y block, how far does the input stick out in relation to the transmission mounting surface? I have a car bell housing and believe truck bell housings are different. Thank you in advance. My apologies on the "Please" Pete
there are 2 truck bellhousings, 1 for the truck 4 speed and 1 for the car type 3 speed. there are mounts on the truck bellhousing for where it sits on a crossmember. if your bellhousing does not have these it would be a car bellhousing this is a truck bellhousing for the truck 4 speed, it is deeper than the 3 speed and has a different bolt pattern for the transmission
So,the truck 3speed and car 3speed,don't have different input shafts? I was told the truck is bigger diameter and also an inch longer
Car 3 - speed is 6 1/8 from trans case to end of head gear. Truck head gear would be bigger in diameter (larger clutch****embly) not sure about truck head gear length. Oldmics
Thank you! Just for addition information: what is the length of the part of the shaft that's turned down and goes into the pilot bearing?
Just for addition information: what is the length of the part of the shaft that's turned down and goes into the pilot bearing?[/QUOTE] Lets call that .775 Oldmics
