Y-Block ?
Discussion in 'The Hokey Ass Message Board' started by RFAGrasshopper, Apr 24, 2012.
  1. RFAGrasshopper
    RFAGrasshopper
    I am always thinking about cars I'd like to build next before I ever get one done I am working on.:D Any way I was thinking about doing a '28-'29 roadster on a '32 frame powered by a Y-block. I was wondering if the Ram Horns exhaust manifolds would fit??
  2. by fitting do you mean between the frame rails? ...
  3. general gow
    general gow
    MODERATOR
    with a Hurst mount up front, I managed to fit rams horns between the rails in the '34. so I suspect you could do it on a '32, unless you pinch the rails to fit the body. Then it might be tight.
    But, you can always go with T-bird manifolds if it doesn't work.
  4. 56 ford custom
    56 ford custom
    from Socal
    As previously mentioned...Yes you can run the rams horns aslong as you arent pinching the frame a whole lot and does depend on steering box and motor mounts. Hurst style mount would be the way to go.
  5. Spooky
    Spooky
    Follow the masters instructions..these engines are so damned cool in an A!
  6. RFAGrasshopper
    RFAGrasshopper
    That's good as I was leaning toward using the front mounts and a truck bell-housing with the rear engine mounts. Thanks,now all I have to do is win the lotto and i can finish the T and build the A right away.
  7. Tom Thomas
    Tom Thomas
    from Nebraska
    You are absolutely on the right track, front mounts/truck bellhousing and if available--crossmember. Gives you the room you need to get the ramhorns installed and run the exhaust. Good luck on your build.
  8. mgtstumpy
    mgtstumpy
    They should, I've a friend with a Y-block in his 29 build. It's at rolling ch***is stage with no body and everything fits.
  9. 56 ford custom
    56 ford custom
    from Socal
    if you need the bellhousing and mount let me know.
