1952-59 Ford Y8 emblem location
Discussion in 'Off Topic Hot Rods & Customs' started by dodg66440, Jan 24, 2016.
  1. dodg66440
    dodg66440
    Can someone provide the dimensions to locate the V8 emblem? Thanks. Y8 locatiion.png
  2. Copper Top
    Copper Top
    Mine has the T-Bird emblem, probably no help to you.
  3. 57Custom300
    57Custom300
    from Arizona
    Owned a 56 way back in 68. Can't give you any measurements but I believe it went in the center of that small area there. Someone here should have the correct measurements.
  4. the-stig
    the-stig
    Tbird emblem here too.
  5. guthriesmith
    guthriesmith
    Mine has Tbird too...
  6. the-stig
    the-stig
    Looks like you ought to put a Tbird motor in it.
  7. Bleach
    Bleach
    T-Bird too.
  8. yblocker
    yblocker
    from Layton Ut
    Hope these help
  9. dodg66440
    dodg66440
    Troy,
    The second pic is a little fuzzy at the bottom and I can't really tell. Is your tape taking the measurement from
    the 1 inch mark making it 6 inches from the bottom? Thanks for taking your time to do this for me.
    Bruce
  10. yblocker
    yblocker
    from Layton Ut
    Bruce, the vertical measurement was taken straight from the edge of the bottom lip to the hole, the horizontal measurement was taken from the corner directly to the hole. I fell off of a 35' cliff and the camera took most of the damage☺ pardon the sloppy pictures.
  11. dodg66440
    dodg66440
    Troy,
    Got it. Thanks again.
    Bruce
