Technical Yet another brake drum fit question
Discussion in 'Traditional Hot Rods' started by Mark Pilant, Mar 17, 2025.
  1. Mark Pilant
    Mark Pilant
    I have a (new to me) 1932 Ford Roadster that really wants new rear brake drums. Unfortunately, there are no markings on either drum. I was told by the shop rebuilding the third member, the axle was from a 1967 Ford F100. But searching around doesn't turn up any drums matching what I have. Here are the physical specs on the drum:
    o 5 on 4-1/2' bolt pattern
    o 11 x 2 brake shows (drum swept width is 2-1/4")
    o Center hole is 2.43" (not the larger 2.77"-ish)
    o From flat surface to top edge of the center hole is 3-1/8".
    None of the local parts places have anything in stock that I would be able to actually check, and I'm a bit reluctant to order without being fairly confident they will fit.
    I need someone to tell me where to go... to get some replacements :p
    - Mark
  2. manyolcars
    manyolcars
    pictures always help
  3. sidevalve8ba
    sidevalve8ba
    '67 F-100 is normally 5 on 5.5 bolt circle.
  4. Mr48chev
    Yuppers, The lug pattern is 5 on 5-1/2 on all F 100 trucks.
    These are the specs on a Delco drum that could fit a 67 Mustang with a 390 from Rock Auto.
    If you click on "Info" you can get pretty good specs on SOME but not all products Rock Auto lists. That includes the depth that on this one is 2.45 inches and important in your quest.
    Then if you click on the part number it gives somewhat of a list of what that part also fits. That list includes several popular 9 inch donors. Screenshot (431).png Screenshot (433).png
    ramblin dan and alanp561 like this.
  5. flynbrian48
    flynbrian48
    Is it an 8" or 9"? With that bolt pattern, I'd guess it's a p***enger car rear. I'm running aluminum Buick replicas from Speedway on the 8" under my roadster, you should be able to get drums for that from any NAPA, O'Rielley's or Auto Zone.
  6. Mark Pilant
    Mark Pilant
    It is a 9". I've posted some pictures here: https://www.n1vqw.net/1932ford/
    Yep. I was pretty sure trucks all(?) had 5 on 5-1/5. So I'm suspecting the backing plate and brakes may have been changed.
    The combination of 11 x 2 drum, 5 on 4-1/2 and small (2.43) center hole is proving hard to find by vehicle.
    - Mark
  7. Mr48chev
    Scroll up to post 4 and check the specs.
    alanp561 likes this.
  8. sunbeam
    sunbeam
    In the early 80s there were some F100s with 4.5 wheell pattern most 1/2 tonns were F150s
  9. Mark Pilant
    Mark Pilant
    Did look at them. The depth is listed as 2.45, which if the swept area is too large. The height is listed as 4.88,, and mine is 3.125 (plus or minus a bit). The photos show a tape measure for reference.
    - Mark
  10. Mr48chev
    It's not uncommon to see rigs with shoes a fair amount narrower than the swept width of the drum. I know there are some out there that have a full quarter inch of space on each side of where the shoes ride on the drum but can't remember what they were now just that they took some paying attention when you were turning them on the drum lathe.
    Not to throw you clear off track but it makes me wonder if they didn't cut down the back lip of a wider drum to fit the backing plates.
  11. Mark Pilant
    Mark Pilant
    The biggest rub, pun intended, is finding a drum which will fit flat against the axle and not rub the rim on the backing plate. The drums don't appear to have been trimmed. But with other things I've seen on this car it wouldn't surprise me. BTW, I've done some poking around on the Rock Auto site (thanks for the pointer) and it looks like a 60's vintage full size ford car with a big block is my best bet.
    Maybe I should just convert to disc brakes :p
    - Mark
    seb fontana likes this.
  12. Pete Eastwood
    Pete Eastwood
    from california
    I believe the drums for the earliest 9" rears (1957-59) are no longer available.
    That may be what you have.
    HemiDeuce and alanp561 like this.
  13. Kosmos55
    Kosmos55
    Try ‘70 galaxies. Those measurements sound like what I have and after 10mins of guess and check at the parts store that worked for me.
  14. Mark Pilant
    Mark Pilant
    Looked at a few early 70s Galaxies and other Ford full size, and they appeared to have a 3+ inch center hole. Way too large. It looks as though a big block '66 Galaxie is promising. I'm going to try and find one of the drums locally and check the actual dimensions.
    - Mark
  15. nutnfits
    nutnfits
    I believe the drums that would wok for you are 60-62 thunderbird rear drums. 11” diameter, small center hole, 4 1/2” bolt pattern. You can use up to 2 1/2” wide shoes with em. Got them at NAPA. I Used them on a 57 ford 9” with original axles and small hole in center of drum. Hope it works out for you.
    sidevalve8ba likes this.
  16. Mark Pilant
    Mark Pilant
    Thank you for the lead on the T-bird drums. They are almost right (same as the ones for the Galaxie I checked out). They are about 1/2 inch too tall. Meaning they would sit on the backing plate before they would seat on the axle.
    I did find an on-line Raybestos application catalog (part number for model and year) that I'm using to check out the actual drums. They only list about 160 drums for Ford applications, so it will take a bit. Fortunately, I can ignore 4, 6, and 8 stud hole drums.
    - Mark
  17. gimpyshotrods
    gimpyshotrods
    Drums can be trimmed on a lathe.
    There are enumerable machine shops around New England (I'm from there).
  18. Mark Pilant
    Mark Pilant
    Well, after a lot of searching, I am still no closer to finding replacement drums. (While drums could possibly be machined to fit, it would leave the next owner in my predicament :) Although I did gather a bunch of useful information. I found: http://squarebirds.org/Manuals/1965/1965-72FordPartsTextCatalog/05-1965Text-Brakes.pdf which gave me the dimensions of some brake shoes along with the ford part number. Using the Ford part number I was able to get an idea of when it was first used. From there, I went to Rock Auto's site and looked through all the Ford vehicles for that year to see if I could find a match for the drum I have. Unfortunately without success, but this may help someone else.
    - Mark
  19. Mark Pilant
    Mark Pilant
    Some other things I did discover: it appears the F100always used the 5 on 5.5 pattern and 11" drums except for 1980 where one option had the 5 on 4.5 pattern but with 10" drums. Sigh. The axle offset I have is 2.36" not 2.5". This, with other clues seems to tell me this axle was a real hybrid; or mashup of (available to the builder?) parts.
    So I think I'm going to try and find a complete kit (drums, shoes, backing plate, etc.) for an axle with a 2.36 offset or see if it is possible for a 2.5 offset kit to work on a 2.36 offset axle. The other possibility is to convert to disc brakes where I know there is a 2.36 offset offering available.
    The saga continues...
    - Mark
  20. wuga
    wuga
  21. squirrel
  22. Mark Pilant
    Mark Pilant
    Warren: I've seen the Quick Performance kit, but it looks like it requires a 2.5" offset. I'll give then a call to see if they can help me.
    Jim: I took a look at the Amazon listing, but there aren't any specifications for the drum so I can't tell if it might work.
    - Mark
  23. squirrel
    might want to look into the return policy, and see if they're worth buying, and returning if they don't fit.
  24. BJR
    BJR
    How about a 1/8" spacer between the drum and axle?
    GuyW likes this.
  25. nobby
    nobby
    if the axle is 57.25 inches outer drum to outer drum
    a 9'' early round back style with early bearing retainer/housings
    it maybe a 57 to 59 ford ranchero axle
    if so, these are them
    Rear Brake Drum 1957-1959 Ford Convertible Ranchero NEW | eBay
    by the way
    10 inches is 254mm
    add
    25.4mm to that to get the
    280mm for 11 inches
    i thought it was 279.4
    hmm
    squirrel likes this.
  26. squirrel
    I seem to recall that the normal 57 cars use 1-3/4 brake shoes, the 57 ranchero and wagon use 2" shoes. Messed me up when I was building a rear out of a couple parts donors years ago.
  27. nobby
    nobby
    yes, you cannot for example
    run a 10 by 1 3/4'' shoe on a 10 by 2'' ford backplate
    they will not sit in the pivot pin correctly
    there maybe bendix part numbers stamped on the back - -10 by 2 and 10 by 1 3/4''
    are different numbers
    i have done diddlied that before
    and THAT was taking a 57-59 axle case 'just for the smooth 9'' round back case' - -fitting 8mm cds and new small bearing ends, running stock 57.25 5 stud small bearing mustang shafts, with 10 by 1 3/4'' backplates/drums, just to run the smaller brakes - -and fitting a WAR centre/pumkin, with a stock 28 splined open diff......... looks great!
  28. Mark Pilant
    Mark Pilant
    BJR: I was thinking of the possibility of a spacer. The only question would be if the studs are long enough to hold the wheel safely on. (Although longer studs could be a possible solution for that.) Now to take the caliper out and measure :)
    - Mark
  29. Mark Pilant
    Mark Pilant
    Well, I think I may have found a solution. I talked to one of the folks at Quick Performance, and he said while their kit is designed for a 2.5 axle offset, he knows of several people running them on axles with the 2.36 offset. The kit is based on 1979 Ford F150 parts, with a brake drum blank drilled for what ever is needed.
    Should be here next week. I'll let everyone know how it goes.
    - Mark
  30. alchemy
    alchemy
    Could put the spacer on the axle, between the flange and the bearing.
    RICH B likes this.
