Projects Yet another F1 build starting up!
Discussion in 'The Hokey Ass Message Board' started by drptop70ss, Sep 25, 2013.
  1. drptop70ss
    drptop70ss
    from NY
    Well there are a lot of F1 builds on the HAMB which is great for inspiration, so now I am starting one too. Just rolled it onto the trailer yesterday to get started and figure out what parts I am going to need. Right off the bat I am hoping to find better front fenders, hood, and doors with hinges. She is rough but savable!
  2. RMR&C
    RMR&C
    from NW Montana
    always nice to see another F-1 brought back to life. Looks like a fun project! Too bad you are so far away, i have lots of extra parts...
  3. drptop70ss
    drptop70ss
    from NY
    Hey I will need small stuff too, PM me with what you have! Swap meets will be starting up so I am hoping to find some stuff for sale. Need a hood latch, gl***, door internals, etc..
    Started dis***embly today.
    stuck flathead, no idea of condition, so it will be sold with the transmission.
    nose removed, nice blurry pic for some reason
    front end all torn down. Plans are for a jaguar front suspension install.
  4. drptop70ss
    drptop70ss
    from NY
    whats the deal with the stock rear suspension?
    I need to lower this thing 4" or so and I figure just flipping the axle to the top of the springs will get me there. How are the stock springs for ride quality? I want to use this as a truck and the orignal leafs look to be in good condition to reuse as long as it doesnt ride like a buckboard since most of the time the bed will be empty. Also why the grease fittings on the leaf spring bushings? Are they br*** or something other than rubber in there?
    They look crusty in the picture but the flash makes them look worse than they are.
  5. fleet-master
    fleet-master
    you guys are spoiled having so much good stuff to play with !! :D ****, I had to make up my own doors...!!!
  6. 55 dude
    55 dude
    Looks like a good start.
  7. fnjunk
    fnjunk
    from Australia
    I love the F1's,what running gear are you going to use?
  8. charleyw
    charleyw
    Always good to see another F-1 build. Good Luck.
  9. gicknordon
    gicknordon
    Leaf spring bushings are greased joints. No rubber in there.
  10. drptop70ss
    drptop70ss
    from NY
    so worth keeping or should I upgrade to something later model? Seems backwards since my 47 cadillac had rubber bushings, was it a HD thing since its a truck?
    Not sure yet, will be something I have on the shelf with either a 5 speed or 6 speed..or an auto. Cant decide yet.
  11. kevinwalshe
    kevinwalshe
    Nice! That's a good start! I can't wait to see this truck come together. Subscribed.
  12. rusty1
    rusty1
    if you flip the rear on top of the orig. springs, you'll need a C notch for frame clearance. I don't think those orig. springs are all that great;...what I do on these F-1's is remove the orig. springs/hangers and replace em with 60's-70's late model Ford, Chev, Dodge truck rear leafs, just bolt em onto the F-1 framerails, then mount your rearend on top of the leafs;...here's a pic.
    good luck with your projects.
  13. gicknordon
    gicknordon
    Theyll last a whole lot longer than rubber if maintained properly
  14. drptop70ss
    drptop70ss
    from NY
    can you be more specific of make and model, and maybe year range of the donor trucks? Looks like you have a chevelle rear there on that setup pictured, I will either be using a 3:08 chevelle rear or a 3:73 2nd gen camaro once I decide on the engine/trans. Looks like that setup will need a C notch as well, I had planned on one.
    The original springs really look pretty good, if I get them apart and the bushings look good then I may just keep them. Not a big deal to hit them with a shot of grease when hitting the front suspension fittings.
  15. drptop70ss
    drptop70ss
    from NY
    Thanks Kevin, your truck is coming along great!
  16. drptop70ss
    drptop70ss
    from NY
    Can anyone comment on how much of a drop you get doing the axle flip and then removing every other leaf spring? That seems to be a common thing to do, I am thinking of doing that and hopefully still having some cargo carrying capacity. If it kills the ability to haul then I will go with the axle flip only.
  17. cobra_4
    cobra_4
  18. RMR&C
    RMR&C
    from NW Montana
    I can't comment on the axle flip, But I doubt you need 11 leaves in the rear springs. I think I pulled 5-6 from each side, that alone dropped it about 3 inches, will still haul anything I want to haul. Rides much better too. If you do the axle flip you will likely need a frame notch for clearance.
  19. drptop70ss
    drptop70ss
    from NY
    If that works that is even better, I will try that first.
  20. oldsman41
    oldsman41
    been a long time ago but I think I took 5 out of my 54
  21. 2racer
    2racer
  22. drptop70ss
    drptop70ss
    from NY
    Thanks but I dont buy bolt on stuff unless it is cheaper than I can build it myself, typical cheapskate stretch the dollar mentality!
  23. drptop70ss
    drptop70ss
    from NY
    Any issues with the rear bottoming out now with the leaves removed? I have read a few threads with guys having that problem after removing the leaves.
  24. RMR&C
    RMR&C
    from NW Montana
    I still have 2-3 inches till it hits the axle bumpers
  25. RAF
    RAF
    from MA.
    Good luck on your F-1 project.
  26. toolman1967
    toolman1967
    Cant wait to see another F1 on the road. Looks like a great find!
    Tim the Toolman
  27. rusty1
    rusty1
    ...those springs pictured came off a '60 Dodge pickup, you are correct, this frame will get a C notch as well; as the photo shows there's only about 2 & 1/2 iches of clearance. That's a full-size late 70's Olds 10 bolt rearend, the correct width to run 8x15 " rear rims.
    virtually all 70's-most 80's truck rear springs will work; look for 1/2 ton trucks with springs about 50-52 inches eye to eye.
  28. drptop70ss
    drptop70ss
    from NY
    We have been slackin..
    Finally got a few minutes today on the truck, out with the engine and trans.
    For those who have ditched the factory engine and trans, did you cut out the factory trans crossmember completely or just the center section to fab a new trans mount? Looks like if I cut it out completely I should put something back to tie the frame together.
    And thats it! Weak update but all I had time for today, will be getting into the Jag front end install soon.
  29. Johnny Wishbone
    Johnny Wishbone
    Whatcha got? I'll see what brown can do for me.:)
  30. RMR&C
    RMR&C
    from NW Montana
    Unfortunately the original trans x member is in the wrong place for most modern trans. If you want to keep the stock brake/clutch location you can cut the center out, but you must stiffen the frame back up again. I cut mine for a T-5 and it really weakened the frame. I built a new X member for the trans mount.
    Anybody looking for parts PM me direct.
