Yet another T5 question
Discussion in 'The Hokey Ass Message Board' started by harleynut45, Jan 23, 2014.
  1. harleynut45
    harleynut45
    S10 T5 install question in a 49 F1 pickup. Will the stock U joint yoke fit up ok to the spline tail shaft and housing of the T5? Thanks Guys
  2. RMR&C
    RMR&C
    from NW Montana
    No, you will need the T-5 yoke and I think a conversion U joint. The drive shaft needs to be shortened to the correct length anyway.
  3. The yoke is different than you original. When I put the t-5 in my Shoebox I had to have the driveshaft shortened 5/8". Since they had to cut the end of the shaft off anyway. I had them put the correct end on the shaft so I wouldn't need a conversion u joint. I figure it would be easier to find a s10 u joint the next time I have to replace them.
  4. harleynut45
    harleynut45
  5. Standard32
    Standard32
    from LA
    When getting a new driveshaft made, the yoke is the same for a turbo 350/saginaw...pretty standard/easy to find at local driveshaft/transmission places.
