Projects Yet another Vicky project
Discussion in 'The Hokey Ass Message Board' started by landseaandair, Sep 7, 2009.
  1. landseaandair
    landseaandair
    from phoenix
  2. landseaandair
    landseaandair
    from phoenix
  3. landseaandair
    landseaandair
    from phoenix
    That's all for now.
  4. nitrobrother
    nitrobrother
    Dang, that's ***y. You sure should've come to the HRH...would've been a great break-in run!
    Dig this angle...
  5. landseaandair
    landseaandair
    from phoenix
    Thanks, woulda been smiling the whole way but wasn't able to get it ***led in time. Been through the immediate neighborhood a bunch though. Neighbors must think I'm lost by now.:)
  6. nitrobrother
    nitrobrother
    ***led? Your car is ***led? Are we supposed to do that? ........:rolleyes:
  7. landseaandair
    landseaandair
    from phoenix
    Yea and to make it worse in this state they can impound any car without current registration and without any numbers on the car they may not give it back.:eek:
  8. bowie
    bowie
    Stylin' ; awesome progress!
  9. landseaandair
    landseaandair
    from phoenix
    Thanks and if anybody's interested, There's a few different length Corvette driveshafts (60s-70s) that may work on your Model A projects. Mine could be late 70s? at 29 1/2" on center. Had to get a new yoke for a 1330? U joint but was able to hook right up to the 9" with a factory U joint for my Torino 3rd member. Can also get adapter U joints if needed.
    Also, even though I've got '53-'56 F100 front and '57 car rear, pretty sure all my brake hardware other than drums-(original), master-(GM) and rear hose-('59 F100) were '66 F100 (Base 2wd). Will need the later T shaped shoe retainers at the top pin because of the spring placement due to now being set up for self adjusters. I also used a strong magnet and disc sander to slightly thin the retainers a third of their width to help make up for the added height from the cable loop.
    One more tip, if you happen to have a '53-'56 F100 box and the length is just a little off, '56 was 1 3/4" shorter due to a dished wheel. Thought my wheel could have been happier about 2" back and when I tore it down for cleanup found a chipped worm gear as they all probably are, turned out to be a '56, and with a new '53-'55 worm and shaft along with a longer tube all was groovy.
  10. desertdroog
    desertdroog
    Looks great Matt!
  11. landseaandair
    landseaandair
    from phoenix
    Thanks, that Plymouth on the road?
  12. desertdroog
    desertdroog
    Not anytime soon. All of my focus is on the A, which goes back to the Haifleys for finishing fab work in June.
    Once that is on the road, then I can get on the Plymouth.
    However, there are a number of kick *** cars hitting Phoenix streets this year, yours just adds to that. Good job!
  13. Whoo hoooo !
    Nice job! Looks great
  14. landseaandair
    landseaandair
    from phoenix
    Yep, gonna be a heap of new/old iron floating around here by the end of the year. Hope to see that coupe goin too.
  15. landseaandair
    landseaandair
    from phoenix
    Thanks, it's weird too see it as a whole car after all these years.
  16. landseaandair
    landseaandair
    from phoenix
    Another year and a few more changes. Roof insert covered and in. Different air cleaner, scoop had some weird turbulence that caused the car to stumble as the secondaries kicked in, with or without filter. Dash rail painted and in. Seat is foamed and covered temporarily with an old Army blanket. Biggest change is the late 70s/early 80s Fish Halibrand copies with 5.60-15 Firestones and 10" Radir slicks.
    79a03b46-47b8-43af-9656-429b83e46241.jpg 587d1a71-a1c7-4bae-9f40-737195f538ff.jpg 83309e76-afac-4804-a04d-fe5bd4b48267.jpg e9230bf5-d7d4-40de-b3d7-2b5836d2b691.jpg
    loudbang and nitrobrother like this.
  17. landseaandair
    landseaandair
    from phoenix
  18. nitrobrother
    nitrobrother
    Awesome. Are you coming out for the Hot Rod Hundred event next Saturday?
  19. landseaandair
    landseaandair
    from phoenix
    If it isn't pouring rain.
  20. loudbang
    Looking real good.
    falcongeorge likes this.
  21. landseaandair
    landseaandair
    from phoenix
    Thanks. I was all smiles when I finally got the wheels on. Went through 2 1/2 sets of lugs and a week and a half before I found some that fit right. All my older mags seem to be drilled to .705 and most mag shank lugs I found were .675, lots of wiggle. Finally got some through Summit that measured .685. A whopping .010 might not seem like much but the difference in fit was very noticeable.
  22. landseaandair
    landseaandair
    from phoenix
    Ch ch ch ch changes.
    251291c8-e2a1-45ee-8ca1-c18def71c399.jpg fe3cdaed-a0d0-4725-ab0e-f374bb2ad3e5.jpg ae851922-e0ba-42cc-9166-d9b28522a8bc.jpg 2ce3fe38-f1e1-4825-a542-50b207758ec4.jpg Wanted or pretty much needed to ditch the shroud and new the Mustang radiator was barely gonna cut it in the summer so I did some reading on a replacement. Found some info on a bolt in U.S. made! Mustang aluminum radiator from Brice Thomas Radiator/C,G&J. Nicely made, brazed core with 2 rows of 1" tubes, a 1 year warranty and only $250.00. Also converted an old aluminum canteen into an overflow bottle.
  23. landseaandair
    landseaandair
    from phoenix
    Got tired of my p***enger breather spewing oil on the freeway. Stamped out a couple louvers to go under the Offy breathers.
    57db4fdd-a39f-4ce2-aed2-ec20cc327c03.jpg 118accee-e8b3-43f8-9f1f-bcc47ccaf4d7.jpg 856074e3-8db6-4da7-adda-a9da2617de46.jpg 86372e05-2c35-425f-8927-0d114f4c15be.jpg 633ee7c0-ef76-4ec4-8864-94ef87ebe447.jpg f0921c15-5bb8-4476-a4b4-d5889bce9712.jpg
  24. landseaandair
    landseaandair
    from phoenix
    Installed.
    Now instead of painting one side of the car with oil at 80 plus, both sides just dribble a tiny bit. Still need to find some fuel cell foam to put in the breathers instead of the wick like pad I got at the hardware store.
  25. landseaandair
    landseaandair
    from phoenix
    And the reason for the cooling system upgrade.
    c10682b8-6b9e-4785-9f18-8eaab6078ad0.jpg 20868d2c-f647-4924-9c93-bdf940b54c39.jpg fc2cbc2c-39a5-45ca-9179-4ad22d7ad109.jpg 6592e928-31fb-45a8-b050-73dc2c3659c2.jpg 94baaabf-198e-4420-82cc-0d6e1d1f71d1.jpg
    Hundred more horsepower!
  26. landseaandair
    landseaandair
    from phoenix
    Also, found this at an estate sale the other day, The Raider! Check post #76.
  27. nitrobrother
    nitrobrother
    Nice! Chip is gonna ****! :D
  28. landseaandair
    landseaandair
    from phoenix
    Probably, we gabbed about the 4-71 a bit that he's been chasing last weekend. Speaking of T buckets, the "Honey Bucket" pic I posted on the Phx thread inspired this shot.:)
  29. landseaandair
    landseaandair
    from phoenix
    Crowning jewel? Got the mini lantern from post #79 cleaned up and installed. Hate the look of 3rd brake lights but had to find a way to fit this thing in. Came from a living estate sale. Guy mainly collected high end prewar cars. Was nickel plated and a little beat up.
    Base had been folded over on one side and creased along with hammer marks. Made a buck and spun it on the lathe at work. Used a radiused steel bar with oil against the tool post.
    0caabff2-4706-41ec-bbdb-90c82ab929b6.jpg cfc640a9-2a5b-45dc-8c11-022e5a9311b9.jpg
    Nickel wore off pretty easy so I manually stripped the rest, buffed it out and bent up a polished aluminum bracket along with a curved reflector on the inside of the barrel.
    aef7776a-f34e-4ad1-8871-482746d6608f.jpg 378cc502-37bd-459e-abd0-846a078a3c4f.jpg 20fb836d-375d-441b-8128-ab5f0715a090.jpg 446c3155-4696-4ad6-8636-0890781d4f34.jpg
    Hard to get a good lit pic, very bright but more of a dull red than in the image.
    loudbang and tb33anda3rd like this.
